Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
wattsup
@TK
With all due respect for your efforts, I can tell you I have read almost the whole thread twice. I still have the opinion that the fake theory stands on peanuts. Also your just posted video shows nothing but false comparisons and an oversized base which Mylow did not use at all. But I guess that is not important.
Again your graph may be showing what is happening but the conclusion is erroneous.
What happens to a wheel that has a given inertia and then meets reduced resistance? The reduced resistance is happening at 180 degrees from the rotors when it comes under the stator because up to that point, the south field saturation of the disk was applying some resistance to at least only 1/2 of the wheel.
For you, this looks like acceleration from an outer source. For me it simply proves the south field does have some influence on the wheel hence on the stator when it starts getting out of the rotor area but not to all the wheel if there is only one segment of rotors.
Regarding startup of the wheel without moving the stator bridge, why not. The wheel is 17.xx in diameter and the forces are being applied to the edge of the wheel going sideways and the force required to move the wheel is truly minimal. If the forces was strong enough to push the stator, then the stator is in the wrong place and the wheel will not turn. Beside, the stator bridge is mounted on a "T" base and to lift that T-base would require substantial forces that are way out of the available forces between the magnets. So again, no way.
It just puzzles me why you guys are seeing things in nothing. His hand did this, his nose did that, his feet were moving, why all this has anything to do with the wheel, I do not know. Next thing we will hear is he picked his nose and greased the bearing. His wheel turned and turned way before any movements were made to stop it so what is the difference in how you stop a wheel.
Again, the Bob Utah wheel was not a stable design since it had more then normal wobble potential. This is not Mylows doing. The wheel came to him like that and he managed to still make it turn on one segment of rotors. He asks his brother to let the wheel go even if he knows it will make some radial turn since the damn wheel is off balance. His, it's ok you can let the wheel go simply means, it does not matter if the wheel turns a bit, just let it go. His brother says its turning, of course its turning, it's off balance. Mylow cannot control his brother on the video and this is perfectly normal and acceptable stuff for novice videographers. Again, no shit to spin there at all.
As for any electronics in the device, come on already. We've been through this again and again.
So again, supporting evidence of fakery is lacking and does not support such an attack on Mylow.
I would recommend one other thing here @TK. Forget about why you think it is a fake. Tell me why you would think it is real. Tell me why this device is doing what it does but remove any fakery theories from your explanation. You will then start to see some things that you did not see before and I am sure you will then think of some controlled experiments that support the device. But again, this is a question of intent.
Yucca
Quote from: nyctuber on May 16, 2009, 04:19:00 PM
http://www.youtube.com/watch?v=r7reVl8vZW0
I love the bird, tempted to get one for myself. I have 3 cats so it is a worry, but I think maybe I could persuade them not to bother it, didn't work for my fire bellied toad though (RIP). But anyways having a bird on your shoulder is way cool, respect!
