Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
0 Members and 65 Guests are viewing this topic.
LightRider
@All...
...as you probably know already...
All Mylow videos are on the BackUp site:
http://www.youtube.com/profile?user=LRCan1&view=videos
LightRider
maw2432
Quote from: lumen on May 17, 2009, 02:29:39 PM
@AZ
When I first noticed the effect I only marked a little dot on a non surface edge because I didn't want it to taint the test in any way. It does not matter which side of the magnet I mark the results are the same.
It also does not matter if I flip over the aluminum sheet, or rotate it 90 degrees or even rotate it in the earths orientation, the results are always the same, SOUTH side drags more or does not hook like the NORTH side.
I need to do some time tests to see if it is an increase in drag or just some hooking effect. I still cannot understand why there would be any difference.
Lumen,
Edit.... retested and now get same results...
I just tried your expirement with a neo and 3" wide aluminum bar and now DO get the same results as you are getting.
I get the same drag on North and South sides of my magnets..... at low angles but it falls away when the South side faces the aluminum...
Anyone else test this?
canam101
Quote from: deseret on May 17, 2009, 02:39:49 PM
MyLow's YouTube account is closed.... agian ...!
Let's hope this is the last time: The saga has gotten old. His audience share has dropped - I think there were only 13 comments on his last video.
And after the analyses showing the rotor slowing down under the stator and speeding up when not under it; and after the video showing mylow's brother holding on to the rotor to keep it from magically moving, maybe mylow figures it is time to call it a day.
I have to hand it to him, though: he has had a bunch of people dancing to his tune for a couple of months.
RunningBare
It did not make sense the first or second time, why should it make sense now, I do know one thing, he will be back.
Quote from: nyctuber on May 17, 2009, 02:39:52 PM
Mylow deleted his channel AGAIN? What happened this time....
Makes zero sense.
nyctuber
Quote from: RunningBare on May 17, 2009, 03:24:14 PM
Agree on all points.
