Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
maw2432
For mylow's new design,
Instead of lowering his stator magnet with spacers or something,  why not raise the base of wheel (rotor) by placing a block of wood or something under it.
PaulLowrance
According to my theory as analyzed so far, in order for the effect to work, the main rotor field must be on an entirely different plane than the stator main field, which appears to be how mylow has it setup. Otherwise, all you get are losses that heat up the cores along with the weak core slowly degaussing.
PL
Grimer
Quote from: PaulLowrance on March 22, 2009, 03:18:11 PM
PL
That would seem to be a nice bit of theoretical confirmation that Mylow and his experiment are genuine -
Cos sure as God made little green apples there is no way Mylow would have carried out such an analysis.
Who is she that cometh forth as the morning rising  -  Fair as the moon. Bright as the sun  -  Terrible as an army set in battle array.
PaulLowrance
QuoteCos sure as God made little green apples there is no way Mylow would have carried out such an analysis.
True, as he's a great follower of the late Howard Johnson, who appears to have been more technical than mylow.  :)
Anyhow, by no means am I saying with nearly 100% certainty it's legit or not until mylow can video his machine on a glass table for at least a few minutes uncut and let a notable scientist analyze his machine. The effect I've outlined is also by no means substantially validated. I only did a quick & dirty FEMM sim without spending enough time to debug it.
PL
Justalabrat
Quote from: CLaNZeR on March 22, 2009, 12:24:33 PM
At the moment standing back on trying to replicate this one due to time :(
But thought I would have play with making up a Armature Magnet the same as HJ's using small Neo's
Find attached picture.
Gonna go pop it on a Linear track later with Stator N poles facing up and have a play.
Clanzer,
Wow! good job on your crescent shaped magnet holder. What is the tip to tip measurement on your magnet holder there? It seems this distance and the spacing between the rotor magnets is critical in getting it to work.
Justalabrat
