Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
Bobbotov
Quote from: Yucca on May 18, 2009, 02:29:45 PM
Yup, it is science 101 but unfortunately it would seem not enough have thunk. And some still fail to thunk.
And yet that doesn't stop them from trying to debunk CoE. Sort of like trying to cut down a mighty oak with a plastic knife.
Quote from: Bobbotov on May 18, 2009, 02:34:00 PM
Hey mister did you forget where you are at. Free energy forum. Just because this case is closed for you don't expect people to tolerate attacks on the whole community.
wattsup
@TK
How elementary of you to honor us with your last video. Now do it from 6-10 feet with 2 lb. test. Remove the flywheel on your motor and just use the shaft. Oh yeh, use your big wheel and turn it simply from the center base. Tell me how it works out for you. lol
@All
Well it's been a pretty busy morning.
Everybody is so happy to discover a new string theory.
The fins have made a great video showing what they want to show.
So this means more shit to sort out.
One question goes to the post made my LightRider here;
http://www.overunity.com/index.php?topic=7039.msg179857#msg179857
Question 1: If those are strings you are showing drawn into the image, please explain how they are to reach the base of the wheel at the angle they are at?
Based on image fin1.jpg below that I grabbed from the Finland video.
Question 2: Please explain why the arrow #1 is not simply pointing to a line in the carpet. Also explain why the line just dissapears in arrows 2 to 4. Oh yes, you can think this is what you see but is it? Who the hell knows. If I look at the rest of the area around 2 to 4, I would say it is just normal and very suggestive to see a string. Also both supposed strings are approaching the wheel at what angle to confirm they are alligned with the wheel base????
Based on image fin2.jpg below that I grabbed from the Finland video.
Question 3: Please explain why, if you purport that the arrow #2 is pointing to a string, then why in arrow #1 I am pointing to the base of the left bridge and you can clearly see the shadow change is just an effect from the lighting created by a normal shadow on the wall. No String, sorry.
Question 4: please explain how there could be a string coming from so far away, put onto the wheel base, made to turn, and then not expect the string to slide down into the union of the lower base and the bearing
Based on image fin3.jpg below that I grabbed from the Finland video.
Question 5: Where is the string?. This image is taken from the same video, same resolution as the whole video that was made. Why don't we see the string? Or was this video pan not part of the focal point of what they wanted to show. lol
Then without photos or anything else;
Question 6: I have been an avid fisherman all my life and have dealt with my fishing lines. I knwo how they stretch, how they contract. So please explain to me from the distance the sofa/motor to the wheel base, how much stress would be reuired on a fishing string to be able to make that big f(*kin wheel turn. The string is on the base where there is the least amount of motive potential to develop in such a scheme.
Question 7: Also please explain that if the fishing string had to be tensioned to such a degree as to create enough holding and turning power on a center shaft, why did this line extension not contract to the point of flying back towards the sofa/motor and not stay within supposed grasping distance.
Question 8: Please explain after the supposed string contracted and Mylow supposedly put it back on the base, how the string stayed intact on the simply straight shaft of the motor/sofa. have any of you seen fishing wire that had to be tensioned stay in tack or stay put when let go. Not me.
Question 9: If you had a string going from the sofa to the wheel base, then how the hell can you leave a cat to possible walk around the room and obviously have the potential of banging into it.
- My Conclusion -
So right now, although all this is very interesting, I cannot say it is irrefutable evidence.
As for the battery/motor on the sofa. He could have left these on the center table after he made his video showing them, and the put them on the sofa to make room for his wheel. So basically, circumstantial at best.
To repudiate such string claims, Mylow would most likely consider making a last video with the wheel in a box or boxed all around showing him walk with a sword taken swings in all possible directions around the wheel.
But regardless if this is fake or not, I am still the moderator here and there are still rules of common courtesy that some members here don't seem to figure apply in all circumstances. WELL THEY DO.
Message to Mylow.
Mylow, no I am not giving up on you and my identical wheel will be in hand this week with magnets next week. I am just tired of this part time, non-paid job of working in the local cesspool. Can't stand the stink and it is taking away to much of my TPU work and there is simply no end to this. Pages grow faster here then an adolescents daily pimple count.
So my recommendation, if you want, make a video showing the wheel start up, turning then take a solid large piece of cardboard and place on the ground upwards near one side and walk it all around the table. Show under the wheel. Whatever, don't pick your nose because guys will say you are greasing your bearing with special dielectrics, don't scratch your neck or forehead because guys will say you have a magnetized cranial implant, don't touch your cat because guys will say you are picking up some static electricity that you then transfer to the wheel. Come to think of it, just show the wheel turning, do the walk around with a cardboard wall then go into a coma to show you are not effecting anything. Good luck. Oh yes, forgot, always drag you feet. lol
wattsup
The "more attachment" feature does not work so I am posting the two others pictures separately.
wattsup
