Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
0 Members and 27 Guests are viewing this topic.
RunningBare
Huh, there's an attack in there?
Now I actually disagree with Bobatov, mainly because I take the stance we are still learning and learning never ends, but I saw no attack in his post.
Quote from: broli on May 18, 2009, 02:36:47 PM
Hey mister did you forget where you are at. Free energy forum. Just because this case is closed for you don't expect people to tolerate attacks on the whole community.
Quote from: RunningBare on May 18, 2009, 02:40:56 PM
Are you his lawyer or something? Must be some sort of double act.
Bobbotov
I am sure you have a whole set of plastic flatware. Bon appetite!
Quote from: wattsup on May 18, 2009, 02:38:41 PM
@TK
How elementary of you to honor us with your last video. Now do it from 6-10 feet with 2 lb. test. Remove the flywheel on your motor and just use the shaft. Oh yeh, use your big wheel and turn it simply from the center base. Tell me how it works out for you. lol
Groan. Do you want me to do it outside too? I can do all of that. Except I can't find any 2 lb test. Would 3 lb. be OK with you? There's no flywheel on the motor, that's a little plastic pulley. See the latest for an example of speed. Why don't you think I could do this with the 5 kilo Mylow wheel? And outside, and showing it reversing, and with lighter line. It's trivial, and you are starting to sound like Sterling. No offense.
I remind folks that I pointed out that Mylow's rig was more stable than it should be on that strange mounting system, IF it were driven from above the edge of the disk. But being turned by a line around the mount, that solves that problem too, doesn't it. Yet another OBSERVATION, that was inconsistent with the old "theory", that is perfectly explained by the new one.
@broli: you're a mensch. That's a good thing, if you don't speak Yiddish. I rotfl.
http://www.youtube.com/watch?v=OuN105wBwsw
wattsup
@TK
3 lb is fine. Remove the pulley and place the string around the center base of your bigger wheel. Good luck. Just watch out though. Them catfish can bite.
Added:
Oh I forgot. Once you have enough tension on that string to make it do what is it supposed to do, take a fish weight thingy and put it on the string to see how much tension is required. lol Then tell me if this much tension can be held back with a motor on its side, held back with a pillow. lol
