Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
0 Members and 36 Guests are viewing this topic.
hansvonlieven
WOW Mark,
That's a bit rough. He'll weather it though. There must be a plan B there somewhere if I read him right.
And the beat goes on, and the beat goes on, la-di-da-de-de...........
Hans von Lieven
LightRider
Quote from: markdansie on May 20, 2009, 12:54:50 AM
More damming evidence,
Implicates his brother as well on the six magnet device
http://www.youtube.com/watch?v=DLLSUV6rNPo
If Mylow doesnt come clean on the Stonehenge with either full confession or an independent validation , he will be very famous shortly. Time to get the mainstream media involved.
Mark
Quote from: nyctuber on May 20, 2009, 01:18:57 AM
Starts at 8:08 in the original video.
Good stuff thanks
http://www.youtube.com/watch?v=NNwhZH8zGD0&feature=channel_page
Quote from: TinselKoala on May 20, 2009, 01:19:12 AM
I'm not so sure that black line is really the drive line. It might only be shadows from the disk that make the black line look like it's moving. The line is also too parallel to the edge of the bureau, and as the camera moves it stays in the same relationship to the edge. And the line must be paired, anyway , I think.
I do think I see the line in another part of that vid, but it's a monofilament, not black. I think.
But this video is clearly a vid of a driven disk, for other reasons, mostly Tony's behaviour and their dialog. And also, look at the very last half-second of that vid. You'll see Tony do a classic "balk" when he's afraid the disk got away from him and moved when it shouldn't have. Even though you can clearly hear the CLICK when Mylow turns off the motor a little earlier.
And how long do they say the time is on the stopwatch? And how long has the motor _really_ been turning at that point? Watch it closely. I see that motor go from Tony's starting it to full speed in 39 seconds. Not 4 or 5 minutes like they are saying right at the same time.
Tony's lines are rehearsed, Mylow is adlibbing and they screwed up bigtime on this take.
The analysis results is understandable? (video with his brother)
http://www.overunity.com/index.php?topic=7039.msg180267#msg180267
no one has commented...
the results say...
A ->the stator and rotor are assumed to interact here -> analysis result: yes, there is acceleration (green - capital letter "A" on the image)
B ->the rotor outside the stator field, there should be slowing down by friction -> analysis result: yes, there is deceleration  (red - letter "B")
C ->freewheel effect, there should be slowing down by friction -> analysis result: yes, there is deceleration  (red - letter "C")
D ->freewheel effect, there should be slowing down by friction -> analysis result: yes, there is deceleration  (red - letter "D")
E ->freewheel effect, there should be slowing down by friction -> analysis result: NO, there is ACCELERATION  (GREEN - letter "E")
F ->freewheel effect, there should be slowing down by friction -> analysis result: yes, there is deceleration  (red - letter "F")
G ->freewheel effect, there should be slowing down by friction -> analysis result: yes, there is deceleration  (red - letter "G")
H ->at the approach to the stator the rotor should ... (conclusion uncertain) -> analysis result: there is acceleration  (green - letter "H")
In the light of this analysis, it seems unlikely that a "sudden acceleration" occurs at the "position E" (GREEN - capital letter "E" on the image).
Furthermore, two other images of this analysis tell us the magnitude (force) with which the disk is accelerated at the "position E"...
...it seems huge, even impossible according to science.
Besides, if we imagine the "string" theory to be a fact in this video, it would be more likely that the "position E" represents the area of friction between the "string" and shaft ... considering the clockwise rotation of the disk, the engine that drives the disk would be left of the disk.
in this video, the brothers were together...
...the data speak for themselves
LightRider
markdansie
Thanks Lightrider
The only thing I can suggest is the weight of the magnets in area E would increase the centrifical force and possibly put more tension on the "string" enabling more grip and thus the accelleration. I may be really of track here but that is my take on it.
Mark
capthook
canam101
Quote from: Yucca on May 18, 2009, 10:28:06 AM
I'll never forget how Touko showed his prowess most admirably when he produced the incredible velocity profile by tracking the yingyang dot. He's the true researcher, he's the hero in this
Plus his video actually showing the wires
http://www.youtube.com/watch?v=bw-8YJvicrw
He deserves our thanks for putting the hoax out of business with a couple of brilliant videos.
As well, Rosphere, in http://www.overunity.com/index.php?topic=7039.3370
nailed the hoax perfectly, and inspired toukoqouko to look closely and provide the proof beyond any doubt:
I went back and re-watched the backed-up copies of the few videos that Mylow made of his device operating on the glass table.  I noticed the following 'technical examples' of a probable hoax.  I suspect that there may be a fishing-line 'pulley string' around the shaft going off-camera to the left and that the camera resolution is too low to see it.
