Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
LightRider
AquariuZ,
You falsify what I write, please don't do that anymore.
the falsified version of my post:
Quote from: AquariuZ on May 20, 2009, 05:52:52 PM
Analysis of Mylow video #6 (April 06, 2009, 03:00:51 PM)
http://www.overunity.com/index.php?topic=7039.msg168839#msg168839
not much data for analysis, but we clearly see an acceleration rather random ...
monofilament line (+motor) => should give a constant curve of acceleration.
hands push => should give an acceleration curve rather than random.
LightRider
the original version of my post:
Quote from: LightRider on May 20, 2009, 05:46:49 PM
hands push => should give an acceleration curve rather random.
LightRider
LightRider
Quote from: TinselKoala on May 20, 2009, 06:38:44 PM
Looks like a noisy signal but with several episodes of motor driven runup. The acceleration periods don't look random to me at all. I mean the timing is random, but the slope of the acceleration, accounting for noise in the signal, is remarkably constant, decreasing as the speed increases, topping out near the same value...I don't think Mr. Hand is that good...but I suppose also that the line clutch could be slipping--recall that this setup is not as stable as his later ones, maybe it has moved and the line tension is less than optimal. It can happen, I know.
And I think I saw the line in nyctuber's recent link to LR's archived copy of Mylow's highres original...but I couldn't swear to it, even though I think it must be there.
This assumption is possible.
LightRider
EDIT:
All first graphical analysis have this "topping" point in common...
It is unlikely that this "constant topping" can be done manually...
Quote from: LightRider on May 20, 2009, 07:20:39 PM
AquariuZ,
Are you saying that he inserted a word into your quote, that changed its meaning 180 degrees, without emphasizing that it was an edit?
I did not catch that. Good for you. Another Orwellian change for the better---his better.
Er, I hate to say this, but that's rather, er...not very kosher at all.
Or even halal.
AquariuZ
AquariuZ,
Dude, calme-toi
I though it was a syntax error. Bad habit trying to correct syntax I agree.
Sorry I entered the word "than" my bad.
You believe he used his hand, I don´t, no need to shout accusations, it is quite clear what you think and it should be clear what I think.
Just to make sure: I do not think he used his hand.
Back to dark mode.
"I though it was a syntax error. Bad habit trying to correct syntax I agree."
Don't worry, it's only bad if you get caught.
/sarcasm
