Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
wattsup
Quote from: Doug1 on June 01, 2009, 01:10:23 PM
Explain fig 8 in the patent. U,V,W are not mentioned anywhere in reference to figure 8. Figure 8 does not look like what is being described.
  Take shielding into account where one wraps a perm mag in tin or metal housing leaving only one open end. All these ends are not equally spaced to line up with the rotor magnets some are off set.The off set is also increasing incrementally so the relationship from stator piece to rotor piece is shifted a few more degrees compared to the next rotor magnet. Normally one would show a view of the windings on a couple pole pieces in a Pat draft and any special phase arangment. No winding are shown in this draft or any of it's images. Is that to enable fig 8 to slip through the cracks with out notice of absent windings. It would only appear to be odd if windings were present except for fig 8. No at all windings would make it easier to slip an image through.
UVW is showing a 3 phase related stator winding and the X and the Dot are simply winding directions up to down and down to up. The whole scheme shows how each phase would be wound from one 3 section to the other in three continuous wires. Alternator stators use a similar scheme then get rectified to DC output. I've seen a guy selling magnet rotor alternators on ebay going back years. I am puzzled as to why they would patent this since there are so many others. If this was really advantageous, it would have hit the market with a major bang already.
Check HJ's patent is much more interesting.
What is a Neo tipped Alnico 8.
markdansie
@wattsup
so how is your Mylow replication going. I think it only fair that you give a report (good or bad) how your replication went. You flammed a lot of people and made a lot of claims yourself. We all have memories.
Mark
X00013
X00013
The above link was done with 18 poles, I cannot and will not confirm 16 poles was reccomended to us.gov.
Jubjub
