Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
0 Members and 28 Guests are viewing this topic.
wattsup
May I recommend that when you guys do any mock up tests of the Mylow system rotor/stator, that you keep in mind to reproduce the main characteristic which is north-cavity-south. Anything else will simply make standard smotting and is not indicative of the technique.
carbonc_cc
Quote from: AB Hammer on March 25, 2009, 08:21:07 AM
carbonc_cc
I think I heard a voice in the background. Daddy can I have my bicycle back?  :'(
Sorry I couldn't resist.
;D
Yea, good thing she out-growed this bike.
I was intrested in the plastic rim and the dimeter of the wheel.
carbonc_cc
I did try and mimic Mylows configuration (with the resources I had).  In my second video, I aligned the mags with N facing up and S facing down and had my rotor mag sideways where N was Pointing left/ S pointing right.  I approached the mags on the wheel with the rotor hitting the middle of the stator mags so that the poles interfered.
                     N  N  N  (Stator North)   ------->  Wheel Movement
(Rotor North)       {N    S}           (Rotor South)
                     S  S  S   (Stator South)   ------->  Wheel Movement
The neo's I believe are just way too strong for the small diameter wheel I was using.
sterlinga
[I posted this last night and forgot to save it down.]
I spoke with Mylow and his brother (Mylowbro).
They got the motor reassembled.
I phoned in just after they got it running.
It was spinning slowly, and slowing down.
It was spinning at 8.5 rpm (~7 sec / rotation)
It ran for 3.5 minutes.
While that might not sound impressive, I asked if it accelerated when it first started, and Mylow said it did.
The deceleration was in the equilibrium speed, which diminished as the magnet degaussed.
Before putting the stator magnet on the stator holder, Mylow said it was so weak it would not even hold up any steel.
What this demonstrates in my opinion, is that
- the motor has a wide window of operation
- the rotation speed is proportional to the strength of the magnet.
Mylobro said he was astonished to see something that defied everything he had learned in school about magnetism.
They were planning on shooting a video and uploading it.
I encouraged Mylow to get some sleep.
Sterling
http://freeenergynews.com and http://peswiki.com
"The best cutting-edge, clean energy news and directory service on the net."
newton2
Hello Honoured Profiles and The Honoured Administrator and The Honoured Anonymous Readers of This The Honourable OU-Forum !
Might I kindly most briefly comment to i.e. socalled "Mechanically acting Permanentes Magnetes Selfrunners"  Devices :
##The importance of interacting Forces when as H-Magnetical-Forces in e.g. 2 moving Objects interacting "Rotors"........the Mythical Classical Mechanics 3-moving-Objects Situation....etc !
##H-Magnetical Force as defined and interpreted per Classical Magneto-Statics , per ElectroDynamics and per the notorious Relativistical Theories.........(and per Else of still not realized Theories....) !
##YES,the importance about the socalled H-Fields´s-Gradientes.....!
##YES,the wellknown Commercial Electro-Technical Magnetical Lifter with "magnetical on-off-switch"
to lift/move iron/steel-objects.......!
##the socalled Integral of ( Force x Way ).........!
WKR & have Yourselves a nice Day and fruitfull experimental and theoretical Results and Benefits of Your hardlabored Doings !
And my kind Thanks about Your All important interesting Participations in and Supportings to
The Honourable Course of OU !
