Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
hartiberlin
Here is a new Video of Howard Johnson´s linear magnet track
accelerator gate:
http://www.overunity.com/index.php?topic=7119
Check it out, it is just great !
Regards, Stefan.
newton2
Hello Honoured Profiles and The Honoured Administrator and also The Honoured Anonymous Readers of This The Honourable OU-Forum !
With my espc. Hello to The Honoured hartiberlin / Administrator with my kind Ref. to #930 :
well, my kind Thanks about the mentioned interesting Link;
well, I got "Sounds & Moving Graphical Lines" instead of a OU-Magnetical-DEvices-DEMO-video-sequence when after having logged-on to the announced Site......by following the written suggested instructions ,such may happen....e.t.c. !
Might I kindly briefly at least mention : YES, to "bring" magnetical Objects "through" "tunnelings" in other Magnetical Objects => such "will" following Elder Magneto-Statics Theses involve a "Path" of socalled "Magnetical Object´s Internal  H-magnetical-Lines"...to say most briefly:
thén NOT is only exteriorly (to the other magnetical Object´s H-field)
being  the Closed Path of Movement of a magnetical Object in a H-field from an other magnetical Object........there might seemingly thén be Mathematical Circumstances to seemingly express a "Gain"-of-Work=>though to precaution about : a type of "Pendant" to Mathematical "Divide with Nil" & "Maths Convergences of Incremental little Amount divided with an Incremental little Amount"=>though thus depending about the Method & the Design of such Magnetical Devices there might be surden "Cancellings-out-of-expected-Gains-of-Works-Amounts",etc....!
Lots of texts-filled A4-pages could be written about such.....including lots of Maths and Drawings , etc....which all are too much of Wordings and Un-Vealings for common Discussions Details in i.e. The OU-Forum.......etc !
And just to mention for to mention: And following surden Calendars-Systems: soon a Date 1.st of April
Y 2009 is to come.....!  At least here in Southern Scandinavia are Spring-alike Weathers following ,that now is the socalled "Summer-Time"....!
WKR & have Yourselves a nice Day and Fruitfull Experimental/Theoretical/Benefits Results from Your All hardlabored interesting important Doings and Participations in the OU-Forum and in The Honourable Course of OU !!
BEP
CNC lathe chuck magnets can be anything from a simple doughnut shape to a segmented doughnut pattern. These are used in production machines for working on smaller piece parts like disc brake rotors and almost anything thing else that may be mass produced.
Platen magnets may be used to hold the tool instead. They can be almost any shape.
In either case, the magnetization method is more complex than applying a magnetic field to the dead magnet. It usually involves freezing or heating the steel to be magnetized. The polarization patterns can be an alternating one - better holding force.
If you watch Discovering Magnetism you can see more of that, you will also see how the trio measured the magnetic field around magnets. The ignorance is so high that this simple procedure of just placing a probe at 1.000's of points in space around the magnet and measuring strength and direction of the field has not been redone. Compared to their technology everything is better and faster in our current time. With the right equipment you get the field 100 times faster than they did back in their days. Which allows you to really understand why the HJ's tracks and motor works instead of just foolishly replicating it.
BEP
Quote from: derricka on March 29, 2009, 01:53:39 AM
Hey BEP, great idea. Building your own magnetizer should be easy.  Start with 120 VAC fed through a 1N4943 diode to charge a 300uF 200V DC capacitor through a momentary pushbutton labeled "charge". Another momentary high current switch labeled "Magnetize" would dump the capacitors charge into a ten turn, 14-16 gauge, wire coil. The coil should wound just big enough to go around the end of the magnet. Of course, with the high voltage capacitor involved, building this circuit into a properly insulated case would be essential. Adding a fuse and a 1 to 5 Meg ohm bleeder resistor across the capacitor would also be a good addition for safety.
P.S. For those tempted to build this circuit:
Don't build this circuit unless you are familiar with proper high voltage safety procedures!
@derricka
Nice work but I would never use house current or suggest it. Too many folks will just cut a cord off their wife's hair drier with shocking results.  :o
My thoughts on this:
Low DC voltage from a large battery is better.
The coil wrapped around the magnet must be considered carefully. I am sure turns around one end will not work well. The coils would probably cover most of the magnet.
Your circuit should work.
The old gas bag that taught me about field flashing instructed using a battery. He said flashing will not work unless you draw a spark when you open the circuit. It didn't take me long to believe him. He wasn't teaching me about re magnetizing small magnets but I think it applies.
