Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
hansvonlieven
Well I must say the appearance of that magnificent cat has changed the tone of this thread.
Good stuff, thanks cat, whatever your name is.
Hans von Lieven
Grimer
Since the subject of monopoles has come up I thought I'd post here a speculation I wrote for 007.
How and why the Mylow Motor works
I think even the most devoted chanter of the TINSTAAFL mantra will admit that if one has a isolated north pole, lets it be attracted to a magnetic south pole  and then waves a magic wand so that it instantly changed into a magnetic south pole, it will be free lunches all round.
Unfortunately I don't have a magic wand.
What about an isolated pole?
Well, I seem to remember from my sixth form physics class that we carried out an experimental determination of the force exerted on an isolated pole on the equator of a bar magnet. Of course the pole wasn't completely isolated but it was isolated enough for our purposes. It was a pole at the end of a barbell magnet which was much longer than the bar magnet we were investigating. As you may remember the force law turns out to be an inverse cube law, the difference between the inverse square repulsion of one pole and the inverse square attraction of the other.
Now if we take that barbell magnet and bend it, look what we get. A horseshoe magnet.
In line with the suggestions made in one of my Overunity.com posts we have cut out the interaction term physically represented by the metal in a bar magnet. The shortest distance between the two poles of the bent barbell horseshoe magnet is no longer metal but air.
But the rotor magnets are also horseshoe magnets, albeit not very pronounced horseshoes. So in the limit the Mylow Motor models relatively simple interactions between a lot of isolated poles (down Basil).
The interaction between a horseshoe stator magnet and a group of rotor magnets is illustrated diagrammatically here.
The fact that the rotor poles are moving parallel to the stator poles indicates that the inverse third power law is involved. The inverse second power law is obviously involved in the approach and retreat of the rotor magnets to the clusters of magnets. Thus we have within group interaction and between group interactions to play with.
Now the essence of the Carnot power cycle is that it is made up of two power laws, an inverse fist power law (the isothermal legs) and an inverse 5/3 power law (the adiabatic legs).
But we have two power laws here as well. In other words we have the necessary components for a BH magnetic power cycle analogous to the Carnot thermal cycle. A Mylow cycle constructed from these components is illustrated here. I have used the HB Cornell convention for plotting the cycle since it is in line with the stress-strain format that I'm familiar with, i.e. with the active action as ordinate and the passive as abscissa.
Since the Mylow Motor appears to be generating sufficient power to keep the rotor spinning against bearing resistance and windage the interactions between stator and rotor must somehow be cycling an area of the BH diagram.
One thing's for sure. This analysis lends support to McCarthy's claim that getting power is just a matter of the way you move magnets around a three dimensional path. Let's just hope he's managed to exploit it as well as Mylow has.
As to the contentious question on where the power is coming from, it has always seemed clear to me that it's coming from the magnetic environment in exactly the same way power can be extracted from a positive and negative offset of the thermal environment or a positive and negative offset of the atmospheric environment. This implies that there must be some absolute zero magnetic potential (pressure) just as there is an absolute zero temperature and an absolute zero for atmospheric pressure. Of course, such a radical change of viewpoint will create such a enormous amount of cognitive disturbance to the existing theoretical framework that it will only be adopted under the extreme duress of.......an explosion of magnetic motors, perhaps.  8)
Who is she that cometh forth as the morning rising  -  Fair as the moon. Bright as the sun  -  Terrible as an army set in battle array.
Lakes
CLaNZeR
My conclusion is Mylow's Stator magnet is simply Iron bar that has been magnetised.
When back at the weekend I am going to get some 1" Bar, drill it with 1/2 Drill down the middle. Cut to length and then cut in half.
Will then try and magnetise each side.
This could explain why they are so weak and also grow weaker. Also could explain the effect that Mylow achieved.
Just a thought :)
http://www.overunity.org.uk
wattsup
@CLaNZeR
Yep, that may be the case indeed. But don't forget that the stator has to be wide enough to cover over two rotors plus the space in between plus one space to the right or left. You may need to measure your current build and make your stator accordingly. I would think a straight piece of iron 1" wide and 1/4" to 1/2" thick that can be curved then cut to the right rotor-space-rotor-space distance would also do. Then use some 12awg house wire and wrap about 10 turns only in the center curve, charge a capacitor to 120 volts and discharge it into the coil, always using the greatest care of course. I don't think a 12 volts discharge will be enough but maybe it is a good (and safe) voltage to start.
