The Last TPU Development On The WWW
Started by AhuraMazda, March 19, 2009, 11:33:27 AM
Tito L. Oracion
Quote from: Bruce_TPU on April 04, 2009, 11:58:21 PM
Hi Forest,
Yes, that is a part of it, but you subtract them (IF's) down, and then you must understand how to use them to create power.  To understand that, look to Tesla and his work in Colorado Springs and his discovery there.
We need to understand that there is a magnetic component attached to "certain" frequency's that are much stronger than a normal mag field.  Create hundred's of thousands of these magnetic kicks within the circumference of the collectors, going in both directions, and you are using Litz for your collectors, and ....
It is amazingly engineered, eloquently designed.  Sophisticated beyond it's years in operation, but relatively simple in parts.  One Mag loop antenna plus three VHF Triode Tube amps.  Some filters, caps and resistors and that's it.  DC Bias the collectors.
We are building...
great !
otits  ;D
Grumpy
Quote from: Chef on April 01, 2009, 04:49:18 PM
I  really enjoying your posts.
Could you maybe tell us more, how do you think the earth magnetic field is different on the southern side?
        -Frank Edwards
Paul-R
If this drawing is accurate, then a compass would not work at the equator.
forest
The drawings are more accurate then older concept but still not correct. Anyway it shows important FACT, in the middle between N and S there is neutral line when induced magnetic field changes polarity.It's so easy to prove it. Just use N-S magnet and piece of soft iron. Slide iron from N to S slowly and you will find what I'm talking about...
Disregarding true magnetic field shape, one should imagine that if Ed Leedscalnin was right and magnetic field is rather magnetic current, it's speed is limited. Thus magnetic field is really an oscillation of very high frequency.
It is easy to imagine once you realize that N and S sources of magnetic current throw tiny particles and each jet need time to reach point in space. In that point of space magnetic field strength is then variable...
giantkiller
Modifying bloch walls by constrictions
References and further reading may be available for this article. To view references and further reading you must purchase this article.
P.-O. Jubert,  and R. Allenspach
IBM Research, Zurich Research Laboratory, Säumerstrasse 4, CH-8803 Rüschlikon, Switzerland
Available online 15 December 2004.
Abstract
The properties of Bloch-type magnetic domain walls pinned in geometrical constrictions are studied using micromagnetic simulations. In agreement with the one-dimensional analytical model proposed earlier it is found that the wall width is reduced in constrictions smaller than the unconstrained wall width. However, the calculated wall type and its width differ quantitatively from those of the model. These differences are related to dipolar contributions and the possibility for the wall to bend outside the constriction
New Method to Measure Directly the 180° Bloch Wall Energy
J. Appl. Phys. 34, 1321 (1963); DOI:10.1063/1.1729491
Issue Date: April 1963
What's New in the Abstract View
ABSTRACTCITING ARTICLES Roland Aléonard, Pierre Brissonneau, and Louis Néel
Laboratoire d'Electrostatique et de Physique du Métal, Grenoble, France
Using the Bitter technique, the traces of a single 180° Bloch wall are observed by a device composed of two microscopes, one on each side of the sample. The wall is twisted by an inhomogeneous magnetic field. The measured displacements of the wall traces are related to the surface energy 0 of the Bloch wall which in turn is related to the Heisenberg exchange constant A.In an iron-silicon alloy with 3% Si we find 0=1.48 ergs/cm2 and A=1.48×10â€"6 ergs/cm at room temperature, in fair agreement with the value A~1.7×10â€"6 ergs/cm derived from Bloch's law and spin-wave theory at 0°K. ©1963 The American Institute of Physics
Permalink: http://link.aip.org/link/?JAPIAU/34/1321/2
And moving it from North to south should prove interesting. Coils at 90degrees might be involved in this. And where would the Bloch wall be in a Toriodial field?
Ref: http://merlib.org/tag/bloch-wall
And another one of our own: http://www.overunity.com/index.php?topic=6759.msg155621#msg155621
--giantkiller.
