The Last TPU Development On The WWW
Started by AhuraMazda, March 19, 2009, 11:33:27 AM
dankie
The TPU is a big waste of time .
When dealing with this kind of stuff , everything you do here is meaningless . If you dont understand how it worked or have a good detailed pic of the build and size you are left with nothing .
The only hope for you guys is if you had a highly organized team that would make every single dimension and brutally test out every dimension/ratio and take note of everything , even then ...
So far theres been a single ugly improvised coil , thats about it ... Is it me or are people getting retarded here ? I see people here trying to explain to eachother in "vague" hypothetical ways how to "tune" a TPU device   ??? ... Mix in a bit of opinions and you got yourself a thread thats FILLED with shit . ;D
Magnon
Quote from: AhuraMazda on March 29, 2009, 05:28:39 PM
@Magnon
If for this effect we need an electron cloud, then would a fluorescent lamp do just as well or do we need a specific type of tube?
This is a good idea.If we have a circular form neon gas fluorescent tube, there is an electron flow in a gas, in a circular path. This is what we need. The speed of sound is about 435 m/s for neon gas. You can use TPU phonon calculator to calculate the circumference for the the tube and needed applied vertical magnetic field strenght. Then add a sound source that is connected to tube, with a frequency that you can have from the TPU phonon calculator also.You can amplify this microwave frequency with a interference, when the signal reflects forth and back in between two mirrors ( vertical reflection )
--Magnon
MACEDONIA CD
@dankie
hey what you are talking  i thing you TALKING SOMETHING  WHITOUT SAYING NOTHING
I SEE  YOU  SAY FOR TUNING TPU  IF YOU ARE ANDERSTEND WHAT IS MEAN TUNING TPU  OR NOT  YOU MAST LEARN WHAT IS MEAN THAT
IN THE END OF MY  SPOKE HERE  I SAY   <YES   IS <VERY VERY IMPORTANT TO TUNE YOUR  PICK UP COILS TO YOUR SOURCE  IF YOU DONT >THEN YOU ARE HAVE   NOTHING
AND  @DANKIE
YOU MAST BE MORE GOOD WHIT PEOPLE  TO RESPECKT YOU  IF YOU DONT  THEN PWOPLE WHILL DONT READ YOUR  SHIT HERE
IF YOU HAVE SOMETHING LIKE TPU   MADE FROM YOU  THEN SHOW HERE TO SEE ATHERE
@OTTO  YES greated  <lamps  you have but  you need 15 watt  to make  heat  and work  properly>.
forest
Otto
If you manage to create tornado in magnetosphere better runaway before explosion. It is the mother and circuit is her baby... Am I correct ?
giantkiller
Listen up boys and girls! We are going to take a trip into the wonderful physix and vortexes.
Now take a stick, an single beater egg beater, or your hand. Ok? Ok...
Take your newly acquired object and swirl it or turn it on in a tank or bowl of water.
The centrifugal force spins the water outward creating a funnel. See?
Lets look on the other side of not only the event horizon but the event boundary.
The event boundary is the wall of vertical force of the air and the water on the sides of the vortex. In the water side of the boundary there is pressure in the water, kinetic and resistive. Not only does the water spin around, and the air too, but forces outward against the resistive action of the water not yet in motion.Guess what happens on the event horizon? We get infolding.
Now put a sprinkle of dark, small gravel or colored sand in the bottom and repeat experiment.
We all know this. But!
In the magnetic version the field sees no resistance! And so it can spin faster and faster right where our copper is. Guess what part of the copper is 90 degress? Thats right! The top and bottom of the windings. From this vantage point the vertical part of the windings has current in it. And guess what it produces? Another magnetic field! Now you have 2 fields at 90 degrees. Let fun begin.
Now what is being drawn into the center? More magnetic field from the aether, sub atomic alignment. As above so below.
Our windings can have 2 configurations. Tall vertically or wide horizontally(PssT... Just like the Deyo base coils on the washers.) Or, OMG! Conical! Either way we collect and distribute current and voltage.
Ok. So now close your books. We're going to have a test. Build it. You will be awarded on performance. No verbal skills are included in the test as the instructions are manual. Not your hands, dummy!
Test hint: Use black pepper and those little blue speckles from laundry detergent in your vortex display. If you can't see this then you're dismissed, permanently.
Caveat: Past performance is not indicative of future status. All efforts will be rewarded.
I figure since nobody from the electroincs class is making anytthing we would just slip down to the home economics kitchen. You know, where the pansies hang out. ;D It's ok. You can play with your food here.
--giantkiller. Class dismissed. Remember: Shock and awe! Be careful out there. I am not for hire. No government would want me around. My current government is dismissing me. The accountants have gone contractor shopping.  That just means I am free to move faster and farther. ;)
