The Last TPU Development On The WWW
Started by AhuraMazda, March 19, 2009, 11:33:27 AM
Bruce_TPU
Hmm...
I have a question for y'all.  Has anyone figured out how Tesla was able to demonstrate power from nowhere?  He just had some tubes, wire caps and resistors.  How about his electric car?  Pretty much the same ingredients.
And then we come to SM and his wonderful, drive you crazy, make you study and think, clues.  Some tubes, some wire, caps and resistors and again we have power from nowhere.  SM gave us all the information we need to understand it, and then to build it, of this I am sure.  But the understanding takes a while.  And then the finer details worked out by experimentation.
Would you like to hear a crazy man's idea of how both Tesla and SM were able to do it?  I will just state the how I think part, not the physics.  I will leave that to more learned men.
Have you ever wondered why SM was so convinced at first that the power "converter" received it's power from the earth's magnetic field?
Have you ever wondered what SM saw in his HV back to back transformer experiment?
I think that Tesla found his magnetometer picking up huge magnetic waves near some thunderstorms.  Later he made a magnetic loop antenna, tuned to one of those waves (Specific VHF frequencies, VLF Magnetic loop antenna)  Then he found that with the tubes he could artificially combine these frequencies over the mag loop antenna and you get power out.
SM perhaps made each collector as a magnetic loop antenna.  Tuned each one to resonate as a mag loop antenna at either 7.23 or 7.3 hz (VLF) This is easy to do with a bit of calculus and is different than "resonance" as one normally thinks of it.  The Magnetic loop antenna is more sensitive to the "magnetic field" and then the "electrical field" for resonance.
The circuit potential is as Lindsay's TPU stack shown many times.  The collectors are tuned to VLF as stated.  The frequencies are artificially created within the circumference of the collector, and then you have the "phenomenon of magnetic collection".  If you have the diameter and circumference of the antenna then you can solve ALL of the other parts.  15" inches in case anyone forgot.
A high speed particle accelerator.
Two triode VHF tubes, three VHF frequencies, and each of three collectors tuned to the VLF, just off of, as SM warned, the frequency of power conversion, or "center frequency with the circumference of the collectors."
Just my latest ramblings... Nothing but speculation, conjecture and theory.  Please pay no mind to me.
Please see the math and theory below to build the circuit potential (collectors) properly.
http://sidstation.lionelloudet.homedns.org/antenna-theory-en.xhtml
Sample from above link:
"The inductive magnetic field across the loop depends on the magnetic component of the electro-magnetic wave (called H or magnetic field strength) and on the magnetic permeability of the loop core."
P.S.  Our electromagnetic waves are artificially tapped into with the VHF three frequencies in the control coils.
Edit:
http://en.wikipedia.org/wiki/Magnetic_loop
Warm regards to all,
Bruce
Mannix
AhuraMazda
Quote from: otto on March 20, 2009, 08:48:21 AM
Hello all,
@AM
I have a lot of informations but I dont think the people here are open minded enough ....never mind.
no, I dont have a self runner, not in this moment. A self running TPU would mean that such a device is working near a runaway point and we have the knowledge to control it. Its no a problem to get into a runaway. Its not a problem to blow the equipment. Its a biiiig problem to control the beast!!!
As Im waiting for my 5U4 tube Im playing with my TPU and my life. The recitifier 5U4 tube is needed to get a DC high voltage mixed with an AC voltage mixed inside this tube. Then this voltage stepped up to maybe 20kV. How else to ger such a voltage??
Yes, a little step up transformer......I know it but......tubes are in this moment a MUST. Not because of fine and clean signals. F..k them. I have now perfect clean signals without tubes. Made just with SS!! The vacuum tube is the best known "connection device" between the aether, the surrounding energy, the.....and a TPU!!!
Not so easy for me to explain. A tube is like an antenna for radiant energy. Somehow it recieves the high frequency particles from the outside and then converts them to a lower frequency, higher energy .....
The same is doing a "CORE" in a TPU. It recieves particles from the surrounding and when you have luck or knowledge to vibrate this surrounding....
@Otto,
I hope you are having fun with your 5U4s.
You said a lot in this post and I have been thinking about it. Are you not going backwards with the use of tubes if you say they are replicating what the TPU coil  is doing? I have been studying the tube specifications and must say I am not very impressed at what I read Unless, the tube that SM was refering to was something special.
Lakhovski developed a special tube described in US patant 2,351,055. Morrey also had a special tube.
Mannix
perhaps we can wait untill someone somebody else makes a semi conductor designed for tpu's
they will post it here of course
forest
I have an idea.Call it crazy but think a moment about it.
What will happen if I sweep magnetic flux over non-induction coil ? I imagine that no current will be generated due to opposite directions of possibly induced currents or in other words : zero voltage between ends of coil.Well,I point to that informations : http://www.hyiq.org/Library/02-03-09.htm, particularly to presented video.
In closed loop of wire sweeped by magnetic flux no current is flowing, but something interesting seems to occur anyway, which was not a point of interest afaik : charges are separated over wire loop.
If that's really happening then kind of sink put somewhere on the same wire should generate current, even in closed loop (of course on wire surface).In other words electrostatic potential may generate current if there is sufficient electrostatic field and in some part of circuit electrons are slightly accelerated on wire surface .
That would be not enough however. Generated so small current must be used then to create bigger surface charge separation by using induced magnetic field. Such device should be consisted of charge separation grids joined by main coils when charges are collected and acceleration coils which will speed-up charges on wire surface and also will rise charges amount on main coils.
