One magnet no bearing Bedini motor
Started by jonnydavro, March 28, 2009, 04:21:55 PM
jonnydavro
Hi.Here is the circuit i am using.The relay i am using can be seen in the picture 2 posts above this one and if you look closely i am only using the relays coil.The way i made my coil was i bought two rolls of 26swg wire.each one had 250grams off wire on and was 170 meters long.I wound these onto a spool i got which had speaker wire on it.I made it like this as it is easy if you start off with the same lengh off wire for each winding and it seems to work good.The standard Bedini coil and lidmotors coil should work just as well as other people have replicated with different coils.It is important to put both variable resistors in.I have the 1k one turned right up to 1k and i just leave it alone and adjust the speed with the 10k pot so i could replace that with afixed resistor but your circuits may behave differently so you want this as a tuning option.Another benefit of adding the relay coil apart from reducing the amp draw is that you can recover bemf from it with a diode and cap.Hope this helps regards jonnydavro.
jonnydavro
Hi.I forgot to put the bemf recovery from the relay coil in so here is the updated circuit.
        regards jonnydavro.
brownsville
@Xenomorph  what is going on in your last vid?
is the magnet needed at all or is the generation coming from the Bedini coil????
@jonnydavro thank you for the skematics and data....I am making an MK jt and will see if this coil can do the same thing with these magnets.
on the first video you picked up the top with the magnet spinning can the system be expanded vertically?
maybe a glass with another magnet above the first.
jonnydavro
@Brownsville.That is an interesting idea.I will try it and let you know.Keep us posted if you have some results with the mkjt coil.
I don,t know if Xenomorph is a member off this forum.I will ask him or you could ask your questions on his utube vids.He is doing lots of  great work on this and his latest video's are very impressive.Here is are links to his latest video,s.
http://www.youtube.com/watch?v=kvALVL_Zjlk
http://www.youtube.com/watch?v=WuHzbRhkKIQ
Lakes
Thanks for the diagram, whats the value of the relay coil caps?
