One magnet no bearing Bedini motor
Started by jonnydavro, March 28, 2009, 04:21:55 PM
nievesoliveras
Quote from: jonnydavro on June 01, 2009, 01:52:40 PM
Hi Jesus and Paul.I think it would be a good experiment to spin a neo sphere inside an aircore trifilar coil with the third winding as a generator coil .The generator coil may be in the perfect position.It would be interesting to see what voltages are generated by a motor like alfacentauro's 150000 rpm job with a third winding.
http://www.youtube.com/watch?v=m1WkxHr0G6o
p.s glad your not leaving us just yet Jesus.I for one would miss you and your great idea's.Regards jonny
Thank you @jonnydavro !
That would be a great idea. That is the point, we need to get useful energy or useful rotation from the inversion on this kind of circuits.
For example if the power goes down. It would be marvelous to just turn on one of those no bearing motors and have enough light to at least have a fan, a light bulb and a tv set working.
Because of the high speeds of this motors it would be almost easy to charge two 12 volts batteries and add an inverter to get the ac voltage needed to do the job.
Good idea!
Jesus
Pirate88179
Here is a video of me running a One Magnet No Bearing Bedini Motor from my earth battery and a 650 Farad 2.7 volt supercap:
http://www.youtube.com/watch?v=rauOlhNK0iY
PYRODIN123321
Hello all, I still can't get mine to work  ??? but i did get the motor spinning with a magnetic switch from a doorbell held close to the rotor, but that's cheating, at least my coil is good...
also I am having difficulty understanding the bedini circuit, it seems to me that the magnets when they pass over the coils make very little voltage just enough in the secondary to turn on the transistor .
the main voltage generated on the secondary winding is caused by the initial charge from the first and once inductance kicks in the secondary no longer has a pos voltage and turns off the coil
Does the breakdown of the field causes a spike in the secondary to turn on the cycle again or would that be an opposite charge to go to charging the other battery then the mags turn on the cycle again?
My setup will not spin the rotors or the snake eggs and even with no resistance to the base it will only squeal in what i think is a feed back loop....but that's the point right...is there a way to lower the frequency of the feedback loop? a larger inductive coil maybe instead of the relay coil? I also have the wrong diodes in there and I'm powering it using a 6 volt batt. so maybe i can replace those and it will work..
Thanks for the help!
I'll keep trying until I get it or it explodes and I loose my hands...
Peace
Peace.
Pirate88179
Pyrodin:
Forgive me for asking this but, I saw on a Bedini page where a guy could not get his motor to work no matter what he did.  Then, some other guy asked him "You do realize this motor is not self-starting?"  The fellow did not.  He was thinking that the rotor would begin to spin up when powered and did not know you have to give it a good spin to start the circuit.  I am sure you knew this already, but just in case you did not, it might save you some time.
PYRODIN123321
 ;D while we are on silly questions the poles of the mag are all the same direction right? I have tried a lot of stuff including spinning the thing by hand to see if i could light a led or something...no go....
I think I'm gonna hook this up to an old oscilloscope I have and maybe I can see whats going on a little better
maybe I should use different magnets the neomags are really strong or maybe take out the core
Peace.
