One magnet no bearing Bedini motor
Started by jonnydavro, March 28, 2009, 04:21:55 PM
nievesoliveras
@all
Congratulations to all that have attained any magnet replication but more to the ones that have attained the levitating magnets.
The problem of the circuit seeing a feedback to the source as a load and stop can be overcome by using only one leg of the pickup coil with one diode with the white band directed to the positive and connected to the source positive.  Or with the band looking away ot the negative and connected to the source negative.
Maybe I used to much words to explain this.
In other words, using just one cable from the pickup coil either to the positive or the negative, but not both.
Jesus
tishatang
Hi Jonnydavro and all,
I have limited internet access and recently looked at your thread.  This is a most awesome discovery!  If I am right, it helps solve problems in another topic, Steven Marks TPU.  Those who are interested can look at my post here:
http://www.overunity.com/index.php?topic=7611.new#new
I did not want to bring this up here and distract the current direction this group is going.  So, I decided to start a new thread suggesting that ideas being developed here be the basis and the heart of a TPU.  You may not know it, but you all are heading in that direction as you start to experiment with different collectors and frequencies of rotation.
For those of you placing the magnets inside the coils or tubes I have an idea  that might work?  Try placing sheets of bismuth inside the coils or tubes and also on the bottom.  Bismuth has the unique property of being repelled by a magnetic field.  See here:
http://www.youtube.com/watch?v=hUoUSz-hD8A
Perhaps the bismuth will repel the magnet inside keeping it centered and prevent hitting the sides?  Maybe also help give it lift?  Just a guess hoping it works.  If one can not find bismuth sheets, I think the lead free shot for shot gun shells are bismuth.  You could melt them down and maybe pound thinner for experiments to center and levitate magnets?
Keep up the good work here and good luck to all.
Tishatang
xenomorphlabs
@Jesus:
Tesla One wire-style? So do you think there is no current needed to do that?
After inducing voltages that are 2V above the source battery , my main concern
now is to reach enough current to feed back to the source (7-10 mA in my setup)
But if the one-wire impulses would suffice that would be SPECTACULAR.
I will try your suggestion for sure.
Would a bridge rectifier work too (just connecting one pole of it to the battery) ?
I was figuring that would make use of the full AC wave, but maybe not for the radiant spikes.
@tishatang:
Thanks for the Bismuth tip.
Theoretically that really could help confining the satellite magnet.
The fact that it is repulsing obviously North and South pole equally is perfect.
The satellite would then not rub against the tube wall AT LEAST not due to the attraction of the bottom magnet as we have it now trying to turn around and move towards it and thereby hitting the wall.
I assume the magnet will still rub against the walls more in a random collision manner like in Eroutt´s videos because the main rotor´s field will attract/repulse it towards/away from itself and thus moving it in the XY axis.
I have no idea where to get that Bismuth stuff, will look into it.
EDIT: Coincidentally a youtube subscriber just sent me an AMAZING link.
It is actually EXACTLY what we are looking for with the test tube magnets.
It uses Bismuth plates and it allows true levitation that will prevent the magnet from hitting the tube walls and insane speeds.
The guy in the video just gave it a burst of air through a straw and states that he has measured 100k RPM on his levitated magnets.
Here is the video:
http://www.youtube.com/watch?v=6g135HwcLZE
That technology could revolutionize wind generators as well. :thumbsup:
xenomorphlabs
I have just tried Jesus suggestion with the one wire coil technique.
Unfortunately the source battery still runs down.
I first used one coil, the two in which i attached one to the plus and one to the minus of the battery (with diodes directed like he suggested)
In the end i even used 3 coils.
I am not saying that this might not work at all, just a very first attempt to do it.
Maybe Jesus has a suggestion on what to improve to to this succesfully?
I wonder if the battery has to be conditioned for negative charging for this too work?
chisel97
Greetings Group, I'm following your ideas with great interest and I'm trying to make time to experiment as well. I got hematite sphere and "egg" working with one of my SSG coils. I'm still waiting for several components ordered for other projects but I have very curious mind :) Idea with using bismuth may be something! Just found this site - http://www.americanelements.com/bifoil.html  they have a bismuth foil, which would be easier to work with. Just an idea...
V-tech
