One magnet no bearing Bedini motor
Started by jonnydavro, March 28, 2009, 04:21:55 PM
gyulasun
Quote from: xenomorphlabs on April 20, 2009, 08:45:01 AM
Would the DC/DC converter beat Lenz law? I mean the timed discharge only affects the magnets motion
during the short time that the cap is connected to the battery.
No, of course not, a DC-DC converter cannot beat Lenz at the input, nor anywhere.
I agree with what you mean on the timed discharge but a timed discharge of the parallel caps (whose positive input wires include a series diode each) may reduce the continuous load that otherwise would be normally present. The timed discharge of the parallel capacitors could be done with one further switch (a MOSFET) just during the time when the charge phase of the capacitors is just off (simply inverse the same pulse to control this 2nd switch)
By low voltage drop diodes, do you mean germanium diodes with 0.3 volt?
Yes, but Ge has 0.1-0.2V drop, Schottky has 0.2-0.3V drop,  this diode question would be important only if you have to fight for the last few milliWatts to save for to get a selfrunner, lol...   use normal Si diodes here if you wish.
Concerning the neon. If i am not mistaken, people have been using neons to send short pulses of energy to batteries due to the fact that at the ignition voltage the neon conducts for a short time while dropping in voltage until the ignition voltage is reached again. I understand that as a simple timed discharge tool.
Yes, ok I misunderstood you.  I thought you want to use a neon for lighting indications as a load and not for triggering, sorry.
rgds,  Gyula
jonnydavro
@Brownsville.Hi.Are you using a 1k pot and a 10k pot and a 100ohm resistor in your trigger circuit?
Are you using a core?
This is my starting procedure.
1. turn 1k pot to 1000 ohms and then leave alone
2.Turn 10k pot to 0 ohms.
3.Spin the magnet.when it is up to speed all speed adjustments are made with the 10k pot
Also i would try running on straight 12v until you get it going.Let me know how you get on.
@All I have tonight done a test on the 40swg pickup coil at 12v so it will be comparable with the output off Xenomorphs pickup coil and the results were quite surprising.The verticle Magnet is spinning so fast and zooming about at 12v and the output was over 47v and still climbing.At one stage it was over 50v and climbing.There seems to be no effect on the magnets speed from the pickup coil.
I did the same test with the angular spinning magnet at that goes up to 48v but the coil has an effect on this magnet and slows it so i think the verticle is the way to go.
Here is a pic off the test.Regards jonnydavro
xenomorphlabs
The optocoupler circuit works nicely to discharge the puffer capacitors.
I connected two pairs in parallel. The timing of the 555 needs to be improved still.
Video: http://www.youtube.com/watch?v=Q6qGvHUPbsY
@gyulasun : Good idea, that way the battery is never connected to the pickup-coils and lenz effects are minimized. I will go ahead and make a MOSFET circuit.
Jonnydavros aircore coils seem to reach higher voltages than mine.
For comparison, i have used 900 turns of 0,2mm copper wire on a 3,6cm diameter spool
The voltage is measured across a 10uF/35 V capacitor.
Can anyone here make a statement about detrimental effects of a too high turncount?
Generally more turns result in higher voltages, but where is the limit at which the resistance of the wire becomes too big (3000+ turns ?)
We want to optimize the aircore coils to pickup the maximal amount of energy
Pirate88179
Quote from: brownsville on April 20, 2009, 09:19:14 AM
Jonny,
I had the same problem as Bill, I redid the entire coil once and rewired everything twice and still couldn't get it up! Thought it was a size problem ;D.
The coil is again torn down - it was the lidmotor version. I tried AA - 2 AA and a 12 volt source with a voltage regulator. Although the lowest it goes is 3.5 volt.
I guess I got too frustrated and am going to rebuild. Need to wait and see if Bill can get one going.
Brownsville
@ All:
Good news!  I have rotation!  I am using the standard Bedini SSG circuit and Lidmotor's transformer coil.  I swapped my 330 ohm resistor for a 100 ohm base resistor (Thanks Jonny!!!) and kept the 5k ohm pot. (single)  I also experimented by moving my core up and down and when I got to about .250" below the surface (1/4") that sucker took off and stood up like you would not believe.  You guys are correct in that you have to reduce resistance right away or that thing takes off for parts unknown!!!!
I am now working on making a better surface for it to rotate on.  I have already destroyed several tupperware bowls in this effort.  I am heating them with a mirco torch and pushing a softball in the to the bottm while it is suspended over another ceramic concave bowl.  This has not worked so far.  I will think of something.  Once I get a better surface, I will produce a video.  It spins....and very, very fast and when it stands up, it is wandering to much and God only knows what happens a minute or so after that.
But, the good news is that Lidmotor's coil and the other stuff works just fine to get this thing running.  Thanks to everyone for all of their help especially Jonny.  Once I get it stabilized, I will enter into other experiments.
Thank you,
gyulasun
@xenomorphlabs
Here is a link on multilayer air core coil calculation: http://www.circuits.dk/calculator_multi_layer_aircore.htm
It also deals with the problem of choosing the optimum geometry to get the highest self inductance from a given length of wire, see the Brooks coil text at the bottom of the link.  An online calculator for Brooks coils is here:
http://www.nessengr.com/techdata/brooks/brooks.html
Others also studied this problem before Brooks and the conclusion was: "There is indeed a “magic value” of coil length to coil radius, which, for a given length of wire, results in maximum inductance. The resulting value of maximum inductance depends upon the wire length, but the ratio is independent of it. The ratio determined from Wheeler’s simple formula is exactly 0.9, that from his more complicated formula approximately 0.814. The maxima is broad."
( quoted from this link: http://www.phy.auckland.ac.nz/Staff/geb/Inductance%20Problem.pdf )   So I think the second link on Brooks calculator is enough for this problem,  by the way your coils seen in the videos may already near to the optimal shape?
Jonnydavros seems to use thinner wire for his coils so his number of turns hence self inductance is higher this explains his received higher induced voltage.
If a thin wire diameter is used, the induced voltage increases for sure but the copper loss also increases. The strange thing to notice is that the higher copper resistance seems to reduce the Lenz effect but in reality the loading current gets limited by the higher coil resistance, this reducing loading effect makes you believe Lenz is getting defeated....
rgds,  Gyula
