The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
giantkiller
I don't think this a postulate or theory.
Just read...
Prior posts referenced  are the Freak wave video and the Coke and speaker demo.
The gentleman with the coke and speaker demo talked about the sun emminating waves that go out and comeback. Nothing new. When returning, these collide with another outgoing set and the collision thats are the most in sync polarity wise create orbits where obviously balanced matter would sit. SM said the tuning had to do the coil's circumference. Could this antennae be right at a tuned Freak wave conjunction? I think so. The ham radio people would have to agree based on the fact that part of the reception tuning is an antennae of a certain mass, length equaling surface area.  ;)
The freqs used were 7.4 and 7.8 the diff is 400hz. I just put that out there. Hadn't seen that number relayed yet. 8)
So I would then think that the collector is tuned to 400 hz while the two generated input freqs create the freak wave or harmonic collision at the coil's circumference. Where , lo and behold, there just happens to be an antennae sitting! 8)
Hey, SM said it was simple. :o
Challenge me or call me wrong....
giantkiller
giantkiller
@Marco
And that is exactly what I am here for friend... ;)
If you gander through all my previous posts, I have always diatribed the most simplest of explanations about current past work, current work and the applications that are just ahead of us.
@thank you comster for documenting what you have done. The setup you have is exactly what I have.  I use bigger copper therefore I need more power and the steps with small copper are getting all of us in the right direction.
SMxx is interesting in that he uses big copper with small power. I need this stage for my next steps. The only thing I have to contend with is getting fire retardant insulated wire. Or loose turns so they don't touch. But that makes a bigger device. Could be useful.
--giantkiller
I slay giants..
Anybody up for lunch at the 'Sea of Galilea' restaurant? ;)
giantkiller
@Kosh
Very good. In the SM17, he runs a tv and you can see a picture. It doesn't matter what the grid freq is 50/60. To run a tv you need AC. The light and probably the drill could run of of DC. ?But the coils vibrate and that denotes a base freq or strong harmonics of some type. If he can get strong harmonics from hash then he truly has done a miracle. And besides, have we seen the hash measurements? More symantics, just like the 'There is no power source that can produce this kind of output.' Once again, true. But that doesn't mean there isn't a small starter source. He still throws a switch. A charged cap?
Pigs fly... :D
Wanna go whale watching off the shores of Nova Scotia?
giantkiller
The waves don't have to continue leaving. On the downside of the signal the field collapses back to the source. Back EMF.
Your IRF840s have internal bypass diodes. So that part you won't see.
But RF is only the speed range of the magnetic wave.
The collector coil is computed to .4hz and sits at the peak intensity of it. Different tuning or running freqs won't Freak! (massive unity) at that point in space.
Transmission, collapse, transmission, harmonic.
Transmission, collapse, transmission, harmonic. 8)
'I gotta go visit a friend in Corazol'. The fishing is great there. :)
