The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 58 Guests are viewing this topic.
giantkiller
http://www.coverpop.com/whitney/
At certain harmonics all the waves hit the line, the collector. 8)
'Then I gotta got to Kioto to see a play'.
giantkiller
This makes the grand assumption that the SM3 and the SM6 use the same freq. 7.8hz.
The edge of the SM3 sits on the inside of the Feak wave and the & SM6 sits on the outside of the Freak wave. If these little devices were right in the middle of the wave (dia of 4.5") they would burn up. So the dia of the 17" could sit in the middle of its large harmonic. But SM uses 2 other freqs to put a smaller Freak wave at that distance. If he decided to use the one freq natural model, the materials in the SM17 couldn't withstand it.
So then, depending on the the desired output you want to control, the diameter & the materials controls the choice of your 1 freq or 2 freqs model.
I said it before: I need fat copper and a reactor. But now just the copper will do. :D
c0mster
mikestocks2006
Quote from: ctglabs on October 06, 2006, 01:39:53 PM
Hi all,
SM says it is very simple, just coils...
Waiting on your thoughts.
Regards,
Dave.
Hi Dave, do you or anyone else here knows if the SM toroid is with closed ends? (one continuous piece of wire? The 2 ends soldered or crimped together?) and then the out put is stepped up with other coil(s) inside that toroid?
As an example using the formulas for toroid with no added capacitors, and only its own self capacitance calculations, it results to a base resonant a frequency of  1.78 MHz
For the following configuration
Toroidal radius 10 cm (to centerline of coil radius)
Coil radius 2 cm
Number of turns 500
Air core
What would happen if the toroid is placed in a proximity of a field of approx 1.8 MHz?
Will the wires melt? Will it start ?kicking? if the pase is slightly off? Will the energy keep on building up inside the toroid?s field? To what levels?
To get to 7.8 Hz and with use of an external capacitor
An example configuration, calculates
External C approx 39mF
Coil radius 4 cm
Number of turns 1000
Air core
What that do it? Using a permanent magnet to start the first oscillation and then let the geofield take over?
