The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 920 Guests are viewing this topic.
mrd10
sorry about my previous post....i get excited
It's possible , could it be , but look again and see, that sm device has two rings
its simple, no mass circuitry just the knowledge of the coils and how they interact with each other.
Yousy
Unbelievably simple, ...is this how the wheel was discovered all those years ago.....lol
Dom     ;)
mrd10
Hi Dave,
Thanks for replying, I thought that maybe I was being too pushy by asking so many questions, I'll have to get experimenting and learning that way.
So to make it in simple terms, regarding the 2 caps and inductor, basically its a ping pong effect, one cap which is charged gets induced into an inductor, when switched that is, then that switch is then in open position, so then the inductor gets switched to the second cap, hopefully with the same charge it started off with going into second inductor and vice versa, so while you put a load on, there should be no loss, as there is always movement from one to the other, Im guessing this is what were trying to do, .......wow.....heheheh  i hope i got that right
Again thanks,
This forum rocks
Dom    ;D
mrd10
Hi Marco,
I can here the echo, this could do with the 2 ring setup, some resonance between the two happening or something to that effect.
Try putting a magnet near by the coils, to see if it makes a difference, perhaps it will boost this echo.
Cheers,
Dom    ;D
gn0stik
Holy crap. I go to sleep and you guys make break throughs without me.
I see how it is. !!!
Congrats marco!..
OK, so the magnet in proximity is a good suggestion. Also, have you placed a compass near by? Seems the voltage would be too small to make it work, but maybe not. Is that a rotating field?
Another note, I noticed the two toroids are of different diameters, SM said the size of the diameter matters. Perhaps if you had two identical toroids it would work better? Or maybe three? Also, what happens when the outermost control is wrapped around the two(or three). There's still a layer of windings missing ;)...
I'm getting excited here folks.
Rich...
