The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 247 Guests are viewing this topic.
giantkiller
supersam
dave,
you have got to go back to thinking in longitudinal waves!!!!! they will be effecting things 90 degrees different than transverse waves.  think about it.  i know you recently did some experiments along those lines.
lol
sam
giantkiller
Quote from: ctglabs on October 12, 2006, 02:44:54 PM
Quote from: giantkiller on October 12, 2006, 02:38:13 PM
Just thinking out loud.
Exactly!  Two loop antenna 1/2 wavelength apart, with collector at 1/4 wavelength to collect this 4x wave, then feed it back!
Question is, does this apply to SM?  We have 3 loop collectors, but then the name implys they wont work in this way.  But what if the small control coils all over the place work in 3's?  Building and building each other in sequence of 3 coils each, which feed the next with their output, which can create rotating field growing and growing at each bunch of 3 by the superposition, and at the same time give power to collectors?  This would also wind up in frequency and could be triggered by noise since the by its nature, superposition will work with the smallest signal?  But then collectors are at 90 degrees  >:(
Dave.
Yes! Maybe a good start would be to use standalone devices, like the block symbols. Just to get this working. We have been doing this in small attempts and steps. ;)
hartiberlin
Quote from: supersam on October 11, 2006, 12:36:10 AM
stephan,
WHY ALL OF THE SUDDEN DO WE HAVE TO WAIT 30-45 SECONDS, WITH A HIGH SPEED DSL CONECTION FOR, "BANNERS", WHEN THE SAME BANNERS ARE BEING POSTED ON EVERY PAGE.  THIS JUST DOESN'T MAKE GOOD COMMON WALK ABOUT SINCE!!!!!  ESPECIALLY SINCE I HAVE BEEN FOLLOWING THIS THREAD SINCE ABOUT PAGE 10.  I KNOW BETTER!!!!! WHAT EVER YOU HAVE CHANGED CAN YOU PLEASE CHANGE IT BACK.  IT HAS DRIVEN YOUR WEB SITE INTO THE DIALUP AGE OR BEYOND!!!!!
It seems the banner problem is solved again.
I did not change anything in the last 2 months,
so there had been a problem with the banners
from ebay somehow.
But it seems, they have solved it now.
If anyone has still problems, just disable Javascript in
your browser, then it will work faster.
In a few days, I will move to a new version of the forum software
and will also install a portal software version, then
I can also again implement longer pages..
Stay tuned.
Regards, Stefan.
giantkiller
@dave, Marco
Hi.
My initial drive circuit doesn't perform correctly. I am running a 74LS139 outputs to a 100 ohm resistors to the MOSfet gates and the MOSfets(BUZ11) don't show a signal at the drain. I put a 74HC244 bus driver in between at the gates, but still not enough voltage/current. I am going to pull the 244 out replace with LM324 opamps as voltage followers for current drive. Any comments?
Also Dave, on your circuit I see that you don't have transistor bypass diodes. The bemf didn't do any damage? My guide here is old school thinking.
Thanks,
--giantkiller
