The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
gn0stik
Cliff, I posted challenges to those statements made the prestigious CEO of MPI. Just so they wouldn't go unanswered.
The article at PESWiki was largely negative regarding Mr. Mark. Nothing against you Mr. Allen, but that's largely why Mr. Mark is so reclusive in the first place. I'm not really feeling all that warm and fuzzy about the fact that Mr. Mark is having to re-read all that slander presented in those links. Although he doesn't reply much anymore, you can be sure he reads this.
At any rate, I'm having a home brew to toast a great week's work by all(taking Lindsay's advice). *raising my glass* Skol! Cheers! Prost! TCHIN TCHIN! A LA TIENNE! Mud in your eye! Hey, Howdy! Bottoms Up!
Oh, and to Giantkiller, perhaps I'm just paranoid, but I've been seeing a lot of black suburbans lately. Anyone else?
Regards,
Rich.
kames
Hi gn0stik,
No, I didn?t use a toroid. I used a standard ferrite rod from a radio it was wound like any standard internal radio antenna but with four wires at a time. The ferrite rod was from a very old radio and somewhat bigger is size that in modern radio. To do it with a garden wire would be a big challenge because a very good winding quality was required. I haven?t tried it using a toroid core. I might do it later. I have small toroids and a big one from a monitor. I did it about 2 years ago and I haven?t forgotten about it. Soon or later, I will come to this experiment again with some new ideas.
Right now, I am thinking about a different experiment. I don?t have yet a clear picture in my head for the actual set up but the idea, for simplicity is next.
The idea is to extract, if possible, any power from two identical charges, let?s say electrons or whatever. Imagine, two long wires in parallel, from north to south. In each wire there is an electron that moves either/or/and north or south. Can I get any power from them? Not yet. However, if I put some magnetic field that creates a pulling force on one elector towards, let?s say, west and another electron, let?s say east the picture is different. So, two electrons, in two wires, each one have an additional force applied and it is in DIFFERENT directions, perpendicular to the direction of the two wires or electrons movements.
I am still thinking about the actual set up for such an experiment.
Kames.
gn0stik
From Mannix:
HYPOTHESIS
Assume the bottom example to be not two separate synchronized pulsed conductors, but as Tesla constructed, a large coil of a few turns of wire.
Stout wire as Mr. Mark would put it. Speaker wire perhaps? Mr. Mark's main work before the TPU was related to audio, specifically speakers.
I assumed that the collectors were stout wire, but not the controls. According to the diagram, the magnetic wave front producing wire would be analogous to controls. This is counter to the construction model that I had assumed. I thought the controls would be thinner wire in "many segments" wrapped around the "stout cable" of "many stranded wire".
Lindsay, Am I getting your description wrong, or am I wrong on my assumptions?
A frequency is chosen, such that the pulsed DC now sets up the magnetic wave fronts such that they coincide with one another in every turn of the coil. At each moving point of a DC "compression" pulse or wave, all the circular magnetic wave fronts would coincide. Imagine these wave fronts when the coil is now compressed into a single annular bundle of insulated conductors. The magnetic wave fronts would become additive, Now place a separate, thick conducting wire within the annular (toroidal) bundle.
OK, more confusion... don't get me wrong, I see what you are saying.. I makes perfect sense, but it's so counter to everything that I've been reading, and the assumptions I've been working under it's kind of throwing me for a loop (no pun intended, mate).
So we've got some thick (relative to my previous thinking)annular controls, short pieces, of a few turns per segment, wrapped around and even THICKER annular COLLECTOR. Is that correct? Now, the controls would have to be a very small number of turns, because being humans it would be very hard to get magnetic "wave" (we'll just call them that) fronts to coincide with eachother in a coil composed of a large number of turns.
So the controls are at 90 degrees, no inductions. Or at least, not the kind standard EM theory tells us is ideal. HOWEVER. We ARE squeezing the hose!
Am I on the right track here?
From the simplistic example above, we can see that the combined magnetic wave front impresses an immense pressure on the electrons at each point of overlap. Thus, a powerful pulsed DC current is set up within the separate, or off-take, current conducting wire. It can be easily visualized that there could be several "step" frequencies that could be pumped into the annular bundle, where more or less such wave fronts coincide. The greater the number of magnetic wave fronts that coincide with one another, the greater the combined coercive force driving electrons through the off-take conducting wire. This is where the analogy of squeezing the water through the garden hose from one end to the other truly makes sense.
Ok, so this solidifies the idea of Shorter bundles of wire, and many frequencies interacting with one another creating a synergy (the whole is more than the sum of it's parts).  If I'm reading that right. I addressed the squeezing in the above commentary.
Rotational magnetic fields have also been mentioned in various dissertations as interacting with gravity. Setting up a DC pulsed ring thus actually does set up magnetic wave fronts that travel around the annular or toroidal bundle of wire and appear to have more and more effect as they all "line up'" and combine to become very powerful as they rotate around the annulus at a minimum speed of C. (As pulsed DC is used, there maybe a significant component of Radiant Energy that comes into play, and it would account for the additional power created, since the annulus appears to "organize" the direction and impact of ZPE into the L system through the collection coil.
So, this is the part that feeds the cornucopia of questions rolling around in my head. It sounds as if you have done this experiment. I note that you say a "minimum speed of C". The combining effect I understand, but that throws me. If it goes over C, then there would most definitely be gravitational effects, which would explain the motive force. However, it brings in a whole new paradigm of thinking about the device, and a whole new paradigm of thinking about it's possibilities. Are you suggesting there are antigravitational effects of the TPU?
Also, this hypothesis blows several theories out of the water. Counter-rotating magnetic fields for one. The reason we are focusing on frequency (not for energy gain, but for magnetic synchronicity). Much of the Bill Beaty stuff we were positive played a part, the schumanns 7.8hz, which I introduced, is not needed, or at least not relevent for the reasons I thought it was.
This hypothesis requires an entire new paradigm of thinking.
Last question: How much of this is theory, and how much is tested? I know this is a learning experiment, but it would help a lot if we knew that this is more than just prostelization. That you have quantified some of it somehow.
Anxiously awaiting your response.
Rich.
