The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
gyulasun
Hi All,
Reading through the threads here I think the answer to Steven question is that once his device needs the Earth magnetic field to operate, then it works in reverse due to the change of the magnetic flux when one passes the Equator? (i.e.? North pole - South pole of the Earth as a gigantic magnet).? More precisely if we imagine the Earth as fat rod or rather a sphere magnet and probe it with a Gauss meter that has a pole identification feature, the meter flips when going from North to South or vice versa.? Correct?
Norbert included an interesting link in German language and I think online language translators can be used to make it much more understandable for those not reading in German, see for instance? ? ?http://webtranslation.paralink.com/?
and copy/paste the link which you wish to read in English and choose  the Direction of the translation German-English (or other language) and click translate. It gives at least a 90% correct English text which is very good for those not knowing any German.
Gyula
Freedomfuel
Quote from: Mannix on March 03, 2006, 08:07:39 PM
YES NORBERT, WE DID TRY THEM SOUTH OF THE EQUATER,? ?THEY WORK IN REVERSE. CAN SOMEONE TELL ME WHY?
Possibly the same reason why tornados turn in one direction in the north hemisphere and in the opposite direction in the southern hemisphere
kames
The answer to Steven question, why the device is working in reverse on another side of the equator is very simple but the explanation is not. The answer is because his device is making use of the earth magnetic field.
I can see two major types of the magnetic devices. One type is observing the magnetic flux from outside, like many standard devices, and making use of the force lines, such as ?cutting? them. The second type is observing the magnetic flux by being within the flux itself, ie being inside it and making use of the energy flow. The energy flow on both sides of the magnet is exiting the magnet, not entering, and entering back to the magnet in the middle, such as on the equator. On one side the energy flow has one polarity on another side the energy flow has a different polarity. I would avoid saying just positive and negative. As a result, if the earth magnetic field is used to generate the ?kicks? and/or the rotating field, the direction/polarity of the ?kick(s)? and/or the rotating field would change in reverse on another side of the equator.
Howard Johnston in his book ?The Secret World of Magnets? with a very simple electronic experiment showed the energy flow of the magnet. His electronic experiment, if doesn?t prove it completely, makes a very tough point about it and it is very difficult to neglect.
Regards.
