The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 82 Guests are viewing this topic.
mrd10
Hi Dave,
I have an idea
referring to the diagram you showed me with sm's 2nd unit.
the 4 coils with magnets on it, wind iron wire in these, connect them all up to the finer wire which is wound on the bottom ring, the larger wire is the output.
Now catch is here to tune the finer wire to the 7.8hz we were talking about, like a crystal radio set.
Has anyone thought of that?
Cheers,
Dom    :D
bluedemon
Quote from: JackFrost on October 23, 2006, 02:15:31 PM
I have read some papers about a connection between gravity and the A-vector and I know that in a wound toroid core, with the magnetic field in the core, the A-vector is in the center of the ring, and that a loop of wire around the core - through the center will indicate the A-vector.
I would venture to guess that SM's device is tapping gravitational energy - hence the "upside down" issue...hmmm
Found this site where a guy is using the A field flux to power other toroids by chaining them with thick wires.  I don't know how valid it is, but it might be worth a test or two.
http://amasci.com/elect/mcoils.html
mrd10
Hi All,
@ Stefan,
Im getting hit with:-
: User 'hartiberlin1' has exceeded the 'max_questions' resource (current value: 70000)
/mounted-storage/home4/sub002/sc11940-GNVW/overunity/Sources/Load.php
1962
it is becoming frustrating.
I have attached a pic of how this may work, Again, im collecting the materials together i need, then off to build it.
Oh to lindsay the clearer pic of 2nd prototype, has made me realize, anyway check pic with notes
Sincerely
Dom
mrd10
Hi All,
Does anyone know what the material of the two rings are on SM's second prototype?
Would it be soft iron?
If anyone does, I'd appreciate your help as I want to buy it, It looks about 150mm I.D to 170mm O.D
Sincerely,
Dom  ;D
dutchy1966
Hi All,
Just found this free energy device on zpenergy.com by an anonymous poster......
Don't know if it's anything like SM's device, but might be helpful.
Regards Dutchy
