The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
giantkiller
I had my real chance for power.
My neighbor left 7 monitors out for trash pickup. I only took 1.
But I have more coming from work.
I am collecting flybacks and jug coils.
And going back to the posts about the imploding tv? That sounds a bit like a hutchison effect. Metal things flying into the tv.
--giantkiller
Thaelin
Just a tid bit, but every time I hear some one talk of the rotating magnetic field inside the torid, I think "Poly phase".
Now just for a moment, lets step into circuit board design of today. If you look at the new high speed designs, you will see trace lines that are doubling back on them selves. That is due to the need to slow down the signal a small bit so it will arrive at the correct time. Hence, a small delay line.
With that in mind, now connect the four coils around the torid in a series. When a signal is applied to the start coil in the string, it will have a small delay due to the length of wire in the coil times 4. The rising and falling sine wave will cause a reversing magnetic field in the coils. Even tho the field doesnt really revolve it acts on the surrounding to make it appear that way. That is how an ac motor works. The rotor is trying to chase this pattern but never quite catchs it.
The magnets form a set field. The rotating field will try and interupt this even if only slightly. Still is a varying magnetic field. The larger the collector, the more it will produce output.
The part that still eludes me is how to pump the input signal without using any input power.
Off on another line, the crystal radio can be made to power a speaker simply by inserting a battery in line with one side of the output to the phones and observing correct polarity.  A crystal reciever tuned to 245mhz will be a direct reciever of solar activity. Use that to power a local osc set to what ever freq you need. More than one could supply the two freqs that are mentioned. Solar power can be quite high depending on exact freq and activity.
I will appologize for my rablings but this thing is giving me a case of the red ass. It should not be this hard to figure out. Yet, it illudes us all to date.
I just purchased a 5000ft roll of #20 wire so I guess on with the winding.
Thanks for the pic, I will see what all I can do with it. If necessary I will contact my friend in canada and see if he can help as well.
later
giantkiller
@Sugra,
Welcome aboard. Sounds like you have a fresh approach. I hope you calculate before you wind. Just a caution. Tired fingers and all.
Most of us have coils and they all work somehow. I have tried using hall effect sensors with my coils and the coils don't produce enough field. I keep at it.
--giantkiller
tishatang
Otto
Can you post a photo or a circuit diagram of your coil?  What size wire, number of turns?
Thanks,
Tishatang
2tiger
QuoteHi,
With the figures you quote this is very possible.  However that inductance is extremely high surely it would weigh more than you could lift.  Also it has no iron core so the permeability will be that of air?
For 16cm radius torroid of 5000 turns, with coil diameter of 2cm, gives us 12.566cm^2 area.  With a rel perm of k=150, the inductance is 5,890mH.
So, the charge will disipate in about 1 second?  Or Perhaps I am talking poo!  Looking forward to you reply!
This could explain the DC output, but not this RF flame discharge?
Hi Dave
Thanks a lot for your reply.
Take a look on the upper right side of my "math-sheet". There you can see that in that example IS an iron core. It could be made of isolated bailing wire, to prevent high eddy currents.
The other mistake you made the area of a circle of 2 cm diameter has a radius of 1 cm.
As long the area is calculated A=r^2 x PI  the area will be =>  1x1xPI= 3,1415 cm^2 and not 12,566cm^2.
And now to the perm.-factor. I don?t know where you get this factor k=150.
In my books I found ?=?0 x ?r  and for ?r of "pure" iron  there is a factor between 25000 and 250000. Well I realy don?t know what pure iron is, so I suggested for my calculation a ?r-factor of 150000.
Nevertheless I found myself a mistake in my calcs. The cross-sectional area of the coil is 0,00031415 m^2 and not 0,031415 m^2.
And refering to the weight I change a few values.
So the new setup of the NRJ-coil is:
-diameter of the torroid 16 cm
-diameter of the coil 4 cm   ->  0,04 m
-windings of copperwire 2500 ,  diameter -> 1mm
-resistance of the coil 6,89 Ohm with preresistance of 28 Ohm -> total 34,89 Ohm
-charging current 5,1 A /  180V
-charging time 9,5 min
-energy stored  14,51 Wh
-coil weight 2,1 kg without the weight of the iron core
With this values you can light the bulb 180V/100W only 8 min instead of 1 and a half as I calcuted before.
If we found out what kind of "pure"-iron has a perm of 250000 we will get nearly 10 Wh more.
In the german version of Wikipedia they show a kind of "amorph metal" with a perm of up to 500000!! See the link:
http://de.wikipedia.org/wiki/Permeabilit%C3%A4tszahl
This "amorph metal" will increase the stored power up to 48 Wh. This means you can power the bulb for nearly half an hour.
Perhaps this is not the secret of the sm device, but with that amount of energy stored in the coil, it could be able to power one of your gravitywaves-recievers and resonant-circuits-ideas.
kr
2Tiger
