The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 35 Guests are viewing this topic.
giantkiller
@sparkman,
I am one of those who followed the wrong. I did notice, and wanted badly to speak about the things you said. My last experience was when I ask a number of those what they believed in. @Mannix was one. We then got the clearest picture we've ever gotten. I didn't know what to say. I know exactly what you spoke about. And I am not just agreeing, but....
It stinks. Your right about the long gray finger. Others have made corrective remarks too. And I don't have all the answers. I just want the one.
--gaintkiller. It is never clear.
c0mster
Dave
I was surprised with the similarities in what the presenter was presenting and experiments done here and some things mentioned by SM. I watched it twice and both times I came away with a better knowledge of why I believe SM's TPU is not a scam.  The whole point about different frequencies being blocked by 2 plates, not necessarily metallic in nature and having impedance got me thinking. I wonder if the material in the SM toroidal is a material with a small spacing that causes the effect. I guess it's back to the lab and see what a pair of flat donuts and some coils produce.
http://en.wikipedia.org/wiki/Casimir_effect
Comster
mflynn44
kames
Quote from: ctglabs on October 31, 2006, 05:38:51 PM
Hi Marco,
I have already tried placing a very strong NiB magnet over and on various places of the circuit and I cannot see any change in this shape.
So, should we assume from this that an external magnetic field has nothing to do with this spike.  This spike can be normal inrush current?  Or can it be caused by something else?
Perhaps Kames can comment on this as his post was rather stern about inrush and the earths field the other day.
Perhaps he can explain it in more detail so I can apply it to this test.
Regards,
Dave.
Hi Dave,
Yes, I can comment on this. I am just too busy with everyday?s b..t and it is difficult to run after you guys.
What you are seeing is such a called ?parasitic? oscillation. It is caused, obviously, by parasitic capacitors. Those parasitic ?C? are coming from everywhere, from you relay, function generator and even oscilloscope probe. These parasitic oscillations are exactly what Tesla said one should get rid of if one wants to see radiant energy. Inrush current (pulse) won?t appear on ?top? part of the pulse. The inrush current occurs only when there is no initial magnetic energy stored in the coil and appears just a little before/earlier than the actual pulse (I mean current). However, the form of the inrush current looks very close to the parasitic oscillation with one exception, it is like a half wave/half period only and always. The inrush current pulse looks like sitting at the front edge of the pulse and starts from the very bottom/beginning of the pulse.
You won?t be able to get rid of parasitic oscillations easily. You can compensate it with other ?R? or ?C? but it always somewhat destroys the sharpness of the pulse. No way around, just a compromise.
A little more about inrush current. I tested it with small coils and big (as much as I could get). With my 50 MHz oscilloscope I couldn?t see any inrush current in small coils. This means that the frequency range (and maybe sensitivity) has to be increased by an order. This comes to a 500 MHz scope. That is why I said that one might need a 1 GHz oscilloscope. With bigger coils I managed to see inrush current a few microseconds in width. If you try to use a big coil with thin wire, you won?t see anything again. With a lot of turns and thin wire the active resistance of the coil becomes too big and ?kills? everything.
Not being able to see inrush current doesn?t mean it cannot be ?abused/extracted? somehow indirectly.
SM?s kick with simple wire. Without talking about something that I don?t know, I can see only two ?types? of kick, inrush current and the actual wire movement. When I tried to put a piece of wire in different directions (North, West?.) it still was jumping, doesn?t matter what. What if there is a way to make electrons to jump out of the wire instead of the wire jumping? Just a stupid idea.
I also have a big question about inrush current. Even so, that it appears having some energy generated, it DOESN?T have a hash signal in it. Remember, SM was saying about a lot of hash noise in his output? But again, who knows how it is being used and if this is a real kick.
Kames.
starcruiser
From the archives at keelynet
RE Stevens coil
I have some info about the stevens coil and scam or not it needs to be
duplicated. While it could be battries, the people who i have spoken with
,one of whom cut it in half have seen no battries other than to start it ,
these people while financially involved are not scammers although the
possibility exists that they are fooled themselves.
this subject alone is worthy of investigation as it is at the heart of any
free energy "toogood to be true" inventions .I am not prepared to give up on
proving the stevens coils as it may be the break thru that we have all been
waiting for,this can be proved by everyone sharing what they know to be fact
and sharing their results it shouldn't take more than a few weeks to put
this matter to rest.
So here is what i have found out 22 turns of 23/0076 lamp wire around a 10
inch wood former . there are capacitors but no info on them. I have used a
14 inch wheel plastic wheel trim with 22 turns of lamp wire and ,wavin a
magnet over the coil gives a rf output which i have not been able to explain
yet.
keep searching
Lindsay Mannix
Western Australia
Regards,
Carl
