The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
mrd10
Quote from: -[marco]- on November 03, 2006, 08:13:30 AM
the setup:
collector coil to scope and voltmeter.
now this is important-> switching potential to ONE of the wires of a control segment.
so the switching potential circuit is never going to be closed.
its just that the switching potential has to be "on" the control but it will never flow.
as you change the frequency you can see all kind of output waves comming out of the collector.
im going to test this a bit further.
marco
*** this only will work with pulsed dc signal , a sine or sawtooth wont do anything.
Hi Marco,
Can you take a video of what youve done or draw a hand drawn pic of how this looks, So to confirm again, you have no input whatsoever and you are getting something out? Are you placing magnets near by?
Thanks and great work.
Dom
Just i noticed to in Sm's 91volt device the wires have a gap, which  must be providing this capacitance effect.
mrd10
Ok here is another thing I was thinking, say if we leave one end of a coil open, and through another coil induce a pulse, could this manifest istelf as a kick?
For this to work, in other words for the kicks to happen, wouldnt we need an open end?
I'm going along the lines that when we first turn on a electic power in a circuit, theres a kick which is induced, so this would mean we would need this condition to happen all of the time.
Am I making sense here.
Marco could you draw a pic and scan what youve done so far?
Thank you,
Dom
rensseak
Quote from: ctglabs on November 03, 2006, 05:50:12 AM
@Norbert.  You say the sound disappears.  Well, if we mix these four frequencys that Tao has found, then we will have a new wave, but the complex wave from mixing four frequencys, can be a new wave which will increase in frequency as it goes, by just using 4 set frequencys which will have a complex phase interactions.  This can be a magic "mix of frequencys within the space of the collector".
We can similate this on a PC  ;D
Dave.
Hi Dave,
I think it would not possible to generate this magic mix of frequencys with a ton generator so that we can observe the kick. There are still other things going on in a wire/coil!  ???
I just want to check the frequencys.
Norbert
starcruiser
Quote from: -[marco]- on November 03, 2006, 09:52:51 AM
@Dom
there isnt much to draw..... it is 3 wires.
two from the collector and one with the pulsing dc to one segment.
@dave
im using seperate devices its not all in one.
marco
Marco,
Are your devices PC connectable? Looks like a PC based scope, right? I have been looking for another scope and function generator that I can link to the PC and the function generator to perform sweeps and FFT analysis. Could you share the models you are using?
Regards,
Carl
mrd10
Thanks Marco,
Look at what I wrote about second device, the gaps are important. otherwise they would not have been wound this way.
Again can a capacitive effect stop back emf from occuring, or can anyone comment by doing this can we have kicks continiung, just a new approach to the whole deal here. I think that this is important, we may have to introduce gaps into the system.  I know Tesla did same as well, I think he did this with power transmitter.
Ive attached drawing with comments
