The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
dean_mcgowan
guys guys guys ..
let me share with you a little event from my week ...
I wasted 3 hours one day re writing 100 lines of code and rechecking every aspect of a program i am currently working on only to find out the method call had been delimited by . instead of ,
.. yep .. sometimes all the experience in the world can make you blind to what is right in front of you. It makes me no less a coder than I was the day befor or the day after the event.
but .. and heres the kicker ...
It wasnt till my graduate student i have working for me pulled up a seat and started to work on the problem,  and I calmly looked over her shoulder and noticed the problem from 5 feet away, god did i feel like a fool, but shit did we laugh as the tension left the room when i pointed out to her what adumb arse i was ...
dean_mcgowan
anyhow  .. back to absorbing the book on magnetic amplifiers .. a scintilating read .. almost as good as playboy ...
ps.. keep up the good work fellas .. i have been reading every post and you are all very encouraging with your efforts and your thoughts.
mrd10
Dave, what SM is getting at is, that there is an interaction between the earths magnetic field and when we first apply current into a wire.
So its a river we can't see, all we want to do is know how to tap into it. Going back to What SM says:-
Now I am you know that anytime you have a magnetic field moving past a wire you have electron flow in that wire or more precisely on the surface.
So the earth is generating the most unbelievably huge amount of power all the time and we can't tap into it?! I don't believe it!  Neither did Nicola Tesla.
He found a way to tap into the earth's power potential and he demonstrated it often.
Did you know that every single one of his patents was purchased by Edison and Westinghouse? He had a very large amount of patents and they purchased all of them but only utilized one for transmitting electric power via 60 cycle AC and step down transformers, which became the standard of power transmission throughout the earth to this day.
Anyway, back to his research in the laboratory. He noticed that most of the time the magnetometers stayed relatively sedate and around the same level. They would fluctuate just slightly. however one day he noticed that the meters jumped quite unpredictably.  It attracted his attention and he began to find that the meters were reacting to a thunderstorm many hundreds of miles away. Interesting isn't it?
Then he continued his experiments and found that as a thunderstorm moved closer the magnetometers would register larger and larger fluctuations until they were off the scale and useless.
He was fascinated and consumed by this. He acquired better magnetometers and his research found that you could tune the magnetometers to certain specific frequencies and tap directly into large magnetic waves. When I say large, I am referring to huge. That was useable power.
However, you had to find a circuit potential in order for the electrons to flow. That was the difficulty which he overcame to produce his famous demonstrations of power from nowhere.
Please let me make another point.
Let us say that you have a magnetic field perhaps it is only a small permanent magnet. Now, you have a single copper wire twelve inches long. If you move the magnet across the surface of the wire from left to right at a certain speed you create an electron flow which is DC and it has a power potential based on how strong the field is and how fast the magnet if moved. So, if you increase the size of the magnet or the speed it moves you create a larger flow of electrons, larger as in higher voltage or more currant.
Everyone tells us that the earth's magnetic field is measured as being too insignificant to generate any useable power, that is not so.
Let me give you something to think about...  If you had a short wire and you moved a magnet across it you would always have limited potential because the length of wire was so short. OK now what if we increase the length of the wire to many miles in length even with a very weak magnetic field moving across the wire you still have a much greater potential flow of power available.  If we put it into a perspective of power per inch it may be easier to understand.
If you have a small magnetic field moving across a wire twelve inches long it can generate an electron flow equal to lets say one millivolt per inch. If you move the magnet twelve inches at the same speed you get 12 millivolts as you transgress the twelve inches of wire. Understand that I am trying to convey a principal that you can understand for use in the future.
So, you have a wire twelve inches long and you can make 12 millivolts moving a magnet across it. If you have a wire 1000 feet long and you move the same small magnetic field across the length of it you can create much more voltage potential perhaps 12,000 millivolts lets say.
So, you have managed to generate a significant amount of electric power with a weak magnetic force.
OK, how does this help us? where am I going with this?
Suppose you have 1,000 pieces of wire twelve inches long and you run the same weak magnetic field over them all at the same time..... you get the same flow of electrons.
If the wires are run in series then you will get the 12,000 millivolts etc. If you connect the wires in parallel you will get higher current but lower voltage.  However, the power potential is the same whether you run the wires in series or parallel.
If you know how to find the circuit potential, you tune into the frequency and you have enough short pieces of wire you can convert as much power as you wish in a given space.
Things are more complex then what I have told you but I am just trying to give you an idea of how the technology works.
How it IS POSSIBLE to use what appears to be a weak magnetic force to generate large useable amounts of power.
girayrd
Hi every one.
I am following the development of this device and find it very interesting unfortunately I have no knowledge on electricity.   I have in my possession the patent (pdf document) concerning this device and would like to know if I shall post it.
Girayrd
hartiberlin
Hi  All, I am currently outdoors standing on a bridge in nature in Berlin Tegel Fliess and am spitting into a small river beneath me and am watching the interference pattern the two spitt droplets are generating on the still water surface.... I guess we have the same inside the big TPU were two rotating magnet fields just generate rotating  interference pattern inside the big outer output coils... So the interference pattern are the real induction generating power outputs...it probably also has no drag back effect and does not load the two sources.. Regards Stefan from outdoors with my PDA.
