The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 18 Guests are viewing this topic.
supersam
hey guys,
WHAT PART OF BE CAREFUL!!DO YOU NOT UNDERSTAND???
lol
sam
starcruiser
Quote from: raburgeson on November 07, 2006, 06:48:25 PM
No not killed but, I bet they are doing a major make-over of the room in their home.
The heat from Q is nasty , several TVs in the past have destroyed rooms, caused
injuries and in one case death. There are documented cases. And you heard the guys that left
saying, there are safer projects to work on. Make no mistake the reality is you are working to create a power generator that can run away on you. Steven Mark and Lindsay Mannix both mention if you do not have experience
in power electronics don't play with this circuit, and install a safty shut-off switch. Seems to me one recommendation was to use a thermistor as a switch trigger. The first of the safty precausions page 7.
raburgeson,
Who was this that this happened to? anyone that was a regular poster here?
carl
Regards,
Carl
mrd10
safety shutoff switch, I'll look into those, there are trip fuses and saftey switches which you use in your homes, would this do?
I will really have to look at the safety aspect, even talk to engineers and electrical persons.
Thanks for the heads up, build safety into it first, is priority number 1.
Cheers,
Dom
raburgeson
I would like to tell you the theory I'm approaching the six inch TPU with to see if you see something wrong with my reasoning. Trying to line up the centers of the magnetic fields I have been trying to run the top and bottom (in parallel) collectors in one rotational direction and the center in the other. I have this crazy thought that the compromise field between the top and bottom collectors will run in parallel will put the magnetic field on the same plane as the center collector. Steven said there are many ways to run 3 collectors like 2 in parallel one in series, or two in series one in parallel. I think that was a very important statement and I hope I am not interpeting it incorrectly. He can only tell us so much. He also said to imagine what happens when 2 fields collide. I tried by experimentation to learn exactly what happens and I also asked Steve and Linsay if my results were right because my equipement is very much less than the lab equipement that developed this device. I'm rereading now, I don't remember a reply to my question though. That may mean the question over stepped the legal bounds of the patented controls. I'm glad you guys are showing advancements in the first device. I'm not holding anything back I just don't have a circuit that delivers any usable VA yet, seem to be getting volts only.
It came to my attention my comment about running the sections in series was confusing. Some people in the group in the not so distant past were trying to run the sections 2 at a time across from each other, in fact the one guy had a avatar with a 2 coil X shaped thing. People kept bringing up Tesla, Gray and others. I was getting a little confused trying to sort out relative material for the TPU. If we can get all the pages back up intact you could see what I'm talking about. Well I'm waisting some of your good bench time so I'll shut up.
Dingus Mungus
Quote from: raburgeson on November 08, 2006, 02:07:20 AM
Weird question:
Does you circut involve applying a solid state magnetic field or "ramping up" in energy like the TPU's?
(I need to reread some pages)
