The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
ronotte
@Mike,
wonderful approach!
WELL DONE
I tried it several time but never succeed due to mechanical problems! I wonder if you would be so nice to explain us how you formed the Al rings and slided into the coax (without braid I understand').
Please let me know about your progress.
I used flat CCs around Al annular rings to take advantage of the two sides wings (particles speed increase) and got interesting results  (4 Seeds instead of one ..with only one coil/1 freq applied). It will be useful to make when possible a comparison with your design as in your case all the particles will be trapped inside the Al hoose and...accelerated.
Roberto
Motorcoach1
@ RonotteÃ,   this was difficult at first then found the aluminum rings in the bath section at Home depot they are bath towle holdersÃ,  :) the coaxl is rgb58 and it does have the brade and insulatin with core. It's a very tight fit and just a lot of pacients pushing it through the tube. the hardest part is getting everything alinged so as not to pinch the coax and keeping everything tight.Ã,  you might want to assit me in the winding next that would be apprciated.Ã,  After the coax is threaded then I bolted it down last to help in the structure , now it's ridged.Ã, Ã,  thank you MikeÃ, Ã,  Ã,  Ã, Ã,  Tolerence is everything so in the ring everything is uniform to size and shape.
giantkiller
Quote from: margiemirage on July 23, 2007, 11:47:26 PM
I have a feeling that this device is the real deal, call it healthy optimism.
What boggles me though is why a seemingly intelligent person like Mark, knowing about the billion dollar oil interests and how they can cover-up competition since they "have the world governments in their pockets", sells the invention to some lawyer instead of giving the technology to the masses before it was buried by the greedy oil bastards. Ten years ago, the internet wasn't what it is today. But NOW he could do it. Why not share it with as many people as possible. There's power in numbers. It's bad enough that the Federal Reserve is a privately owned bank with no reserves and that the big bankers have been stealing our money through the biggest fraud ever perpetrated on a nation called Income Tax, which btw is unconstitutional. But now we can't even have this? Just lowers his cred me thinks, especially when he brings God and mission into the picture. But hey, I don't have anything to lose by hoping. Good luck Steven and God Speed to ya.
-Margie
1996 was prior to the tech wreck. There were people vieing to get their retirements pumped up from the failed oil debacles of late 80s. Technology was still the panacea of the new age. This was the age of fat money and once again no boundaries. I was offered alot of money for what I do and refused. Other people's money. The question that I have always had and has not been addressed in any manner is: If you were involved in this or saw this then what would you be doing now? Who are all those other people in the videos? Do you think those people just upt and died?
--giantkiller. What is truely under the covers and at stake here?
Motorcoach1
Gerogr toborie died at the age of 93 in berlin i beleve great play wright and insprantionist
ronotte
Hi Mike,
for CC winding there are actually two philosphies:
1 - From Otto which says that bobbined type is easier & gives better results. well I tested the bobbin way and found good results as per Otto's indications. ATTENTION: the bobbin MUST be wing shaped as per his dranwings!.
2 - From others which say that flat type is better as the coil is for this case 'like a transmission line' (if I remember well) and in this way there is more 'collector covering'. I say also that if you are planning to implement a rot mag field then the flat kind is almost mandatory as you must cover all the collector (in other words the 3 or 4 needed coils must be set one near the other).
At the moment I'm experimenting with flat coils...but for the moment I can say that I don't see better operations!.
Roberto
