The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
gn0stik
From Bills site:
http://amasci.com/freenrg/a-vectFE.html
QuoteIf there is an energy gain, then probably we can wind a small pickup-coil onto the inductor of the tuned circuit, then connect the terminals of the donut-coil to this small pickup-coil instead of to the high-frequency generator. This will form a so-called "stand-alone closed-loop free energy device." Without some sort of governor mechnism such as some back- to-back Zener diodes connected across the tuned circuit, the ZPE energy would build up within fractions of a second and cause a piece of the wire to melt (or perhaps the whole device would vanish in an immense flash and a clould of green copper-oxide smoke.)
Are those things pickup coils?
As for the magnets.... I'm not sure, I've gone back and forth from thinking that they are "smoke and mirrors" to being certain they are necessary.
The reason I was thinking they were smoke and mirrors because without them, the device is simple to look at and determine all the necessary components.
Bill beaty talks about the shorted secondary coil which the "kings electrons" go down and find a dead end, and then jump wires. I thought that perhaps the magnet starter was to create an initial inductance in the coil, which in turn begins the process of the electrons running down the wire, and hence a magnetic field. This magnetic field forces the magnetic field of the permanent magnets to re-orient in it's presence as it move around the coil, and move back into the coil once it has passed.
I don't really, know, it's all speculation, really.
What get's me is, I have a feeling that if a different frequency were chosen, they wouldn't be necessary at all. However I also have a feeling that if a different frequency were chosen, we'd just be stealing energy, and that's cheating... ;) Everything is free when you steal it, even energy. Again, just speculation. EVERY OTHER ASPECT has been nailed down.
I've sent Bill an email inviting him to this discussion. If he's ever experimented with this, I told him I'd be willing to pay him a visit.
Regards,
Gn0stik.
bob.diroto
Hi Tao & gnostic,
Found these videos which demonstrate interesting resonant phenomina:
http://www.youtube.com/watch?v=sY6z2hLgYuY&mode=suggested&search=
http://www.youtube.com/watch?v=Zkox6niJ1Wc&mode=suggested&search=
Although sound is used it's the same principle for electromagnetic waves going around a coil or on a plate or round the circumference etc.
The reason I bring this up is that Tesla observed that disruptive discharge (i.e. kicks) caused different metal objects to accumulated different levels of charge based on their size. In other words this energy that comes from a kick has a specific frequency. If we want to gather this energy on a metal plate, pipe or using a coil we need to know what the frequency is so we can gather the energy effectively.
I'm almost certain I know what the component are in the video clips... but just checking before posting.
bob.diroto
The yellow tubes are high voltage polyester capacitors. I've checked the Steven video these yellow tubes have wires coming from them which can be seen at certain angles.
http://hometown.aol.co.uk/oldradioparts/cap.jpg
The two toroids are transformers for sure. 1 transformer for each driving frequency I'd say. Without knowing the number of turns I cant say whether they are increaing or decreasing the voltage. I suspect the turns are the same in which case they are acting like isolating transformers.
The wire and number of turns looks awfully thin to be chucking out any sort of heat. The heatsinks underneath the toroids I think are for high voltage switching mosfets. These mosfets would be used to generate a high voltage square wave with a sharp rise time. I've used these mosfets for exactly this purpose and they get incredibly hot (car ignition project). Also you would never mount the item generating the heat on top of the fins but underneath.
bob.diroto
The magnets also mystify me. In some of the videos they really don't appear to be closely connected in any solid fashion to any of the circuitry. My thinking is that they are connected to generating larger kicks. Perhaps it is the presence of this magnetic field which causes the kicks to manifest to a level that allows cascading to happen ?
rensseak
It looks like that every part is doubly present. similar to the thestatika.
@tao
ok, he use only one magnet to the small coil but maybe he just adds only the second magnet! Who knows?
