The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
bob.diroto
Quote from: tao on July 02, 2006, 03:35:15 AM
Quote from: bob.diroto on July 02, 2006, 03:33:29 AM
Quote from: tao on July 02, 2006, 02:28:22 AM
The NUMBER ONE THING that shows that Steven is AT LEAST using Tesla's/Gray's processes is the FLAME LIKE DISCHARGE that comes out from Steven's wires when he shorts them in the video, that is NOT NORMAL ARCING, only PROPER RADIANT CAN DO THAT.
No. The flame like discharge is a hall mark of very high frequency, high voltage, high current electricity.
It may also be a hall mark of radiant electricity but it is not exclusive to radiant electricity.
Is the high frequency usually PURE WHITE? I haven't seen such, so excuse my statement if such is the case. Just from what I have seen, Tesla and Eric Dollard describe the output from the Tesla coils as pure white streamers that have flame like appearances, quite unlike normal high frequency outputs.
Just as a case in point, all those Tesla coils that output the purpleish streamers are NOT TRUE TESLA TRANSMITTERS.
I've used high frequency DC arc welders. They produce EXACTLY the flame of pure white colour if you try to weld too thin a piece of metal. In fact the edges of the flame will turn slightly different colours, depending on the metal vaporised, as the vaporised metal changes state. You can just see the colours when viewing the flame at the end of the energycoil.mpg movie, but the camara is having a hard time dealing with the high brightness of the flame.
It was this movie that convinced me that this TPU device was for real.
That sort of energy should need a BIG power unit!!!
It's fairly frightening really I've had a shock from an arc welder that was current limited.
One second you're in the booth and it appears to you that the next second you are outside of the booth 1 meter away...saying what the hell (actually you say a lot worse than that). The burn lasted weeks.
The guy in the movie doing the demonstration 'flame' is a total nutter (in the nicest possible way) for
a. Not wearing gloves.
b. For holding both contact in his hand. One arc and it's a jolt straight across the chest.
As a warning to all in general.
For those that aren't aware, contrary to hollywood, when you receive an ongoing shock all your muscles tighten stiff. You are not actually flung back. What happens, is you loose awareness (not necessarily consciousness), if you are lucky enough that the tightening of the muscles disconnects you from the source of shock, you stumble backwards, as a standing tightened muscular frame has a balance point that tips you backwards, your body if it can regain control of the muscles will try to keep balance, at some point, your awareness returns. From your own point of view it is an instant of time between the start of the shock and picking yourself off the floor a couple of meters back. Your mind infers that you were blasted backwards at high speed.
If you have a penchant for touching bare wires, a neon test screwdriver is handy as it'll glow to almost any kind of reasonable high potential (100+V) with even a small current behind it, be it AC/DC or high frequency. Second having confirmed that the wire is not live, never first touch with your fingers, use the back of your hand. By using the back of the hand, if there is current on it, that will shock, your fingers will tighten over just air, and almost certainly disconnect you from the shock. Unpleasant but liveable. If you use your fingers, your fingers will involuntarily grasp the cable tighter and you will almost certainly die as there will be no Residual Current Device to break the current.
bob.diroto
Quote from: penguin hood on July 02, 2006, 07:25:21 AM
This is an interesting thread, I do not know too about the devices you talk but I have designed and tested a electronic high voltage pulse generador. If can be useful for some purposes I can post all information to be built.
Goals:
Max voltage no limit.
The very short switching time and remain constant no matter the max voltage used.
The pulse duration and active cycle can be controlled exactly.
Drawbacks:
The component numbers increase lineary with the max voltage.
Very low load current.
Thank you very much Penguin Hood. That would be most appreciated.
Your experience with designing circuits/electronics experience will be very useful.
I might have a couple of other circuit outlines to run past you in the next few weeks.
Liberty
Quote from: Liberty on July 02, 2006, 02:13:44 AM
It is interesting to read about the different devices and how they work.
It appears to me that Tesla and Ed Gray use the spark gap to collect a "moment of excess power" via the spark gap effect and collect it in another device that stores or uses the power.
The SM device would seem to tap into the magnetic field of the earth by using another magnet with iron wire to create a mask field and collects the difference between the fields (about 5khz).  I believe this to be the 'conversion process' that SM talks about in his video.
I think all of these devices are collecting what is termed, 'radiant energy'.  The same energy that Dr. Moray found.  I think that these people have found different methods to collect power from the same source.
I would favor the SM device overall, because it collects this power on a constant basis, like Dr. Moray's device did.  The SM device and the aerial generator patent have a similar concept of collecting this energy.
To elaborate on a hypothesis:
"It appears to me that Tesla and Ed Gray use the spark gap to collect a "moment of excess power" via the spark gap effect and collect it in another device that stores or uses the power."
A spark when discharged emits frequencies.  Many frequencies across the entire spectrum band, but for an instant.  (Like how you hear static discharge on the AM radio at any frequency).  This frequency discharge must interact with the special frequency that taps into this radiant energy.  (My guess is in the Ultra Violet range of frequency, where I believe that magnetism resides).  The 'radiant energy' piggy backs or is modulated onto the energy of the original spark (similar to how audio on an AM radio carrier travels) and can be split off of the original spark energy and stored or used.  Just a guess, but this is my guess as to how this energy is made available to use or store in a tesla or Ed Gray style device.
Liberty
Liberty
Additionally, I will go on to say that the aerial generator and the SM device, appear to use the frequency of a local magnet (through the use of iron, or steel wire) to mingle with the magnetic field of the earth. (After conversion of the earth's magnetic field in iron wire, while mixing with that of the local masking magnetic field, resulting in a 5-6khz AC output?).  It appears that the iron/steel wire may have a similar capablity to that of fiber optics.  But it has more to it.  The fiber optics carries the laser light.  The iron wire may carry the magnetic field and frequency.
If two such wires were placed near each other, one being attached to the local magnet (from N to S pole) and the other iron wire attached at one end of the local magnet and then fed into a toroid with copper windings, cut to frequency of about 5-6khz.  Perhaps this is the essence of the SM device?
Just something to think about.
Liberty
Liberty
Liberty
The previously attached drawing of a possible TPU configuration has expired.  This was an Independence Day special attraction only!  This circuit is for educational purposes only.  :)
Disclaimer:  Warning!  The circuit may be capable of producing hazardous voltages or other safety issues.  Do not build or use the circuit as it is intended for educational purposes only.  If you choose to build or use the circuit or any part thereof, it is completely at your own risk.  The 'possibletpuconfiguration' circuit may or may not work.
Liberty
