The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 58 Guests are viewing this topic.
hartiberlin
Hi Bob,
please try to use iron wire coils in your setup.
Try to premagnetize the iron coils with a magnet
as close to the Barkhausen jump magnetisation level
as possible with the right distance of the magnet
and put a cap in parallel so you have a LC circuit.
Then give it a kick via an electric pulse and see,
if it will resonate at the Barkausen frequency
or lower frequency, but make sure the oscillation
will drive it always through the Barkhausen regime,
so you will see some spikes on the oscillation voltage.
Now if you have the iron wire coil on a ferrite core and
couple these spikes to another iron wire coil with a cap in paralell
you could see, if you could resonate this LC circuit as well
and finally try to feedback some energy to the first LC circuit with
some additional circuit.
Please try step by step.
Many thanks.
hartiberlin
P.S: Bob Shannon, who made this Barkhausen effect receiver said to me,
that the Barkhausen jumps occured also with a static magnet sitting
at the right distance away from the iron material. Then the jumps were
quite low in counts, but some domains flipped back and forth,
so there is some energy generation via these jumps occuring in this state
due to the temperature and background radiation which kicks
some magnetic domains back and forth.
So if you would have a sine current which goes through this regime,
it would also flip the domains back and forth and the spikes
of this flipping would induce voltage spikes that could be collected
in a bigger cap.
This is probably the big electrolytic cap in Steven Mark?s bigger 1 KW unit
inside the toroid.
Regards, Stefan.
bob.diroto
Quote from: tao on July 02, 2006, 05:52:16 PM
I want to first say that I in no way want to deviate from the RADIANT TESLA/GRAY line of discussions, because ultimately I feel that is the ONLY PLACE where FREE ENERGY IS, but I found this today, and I couldn't get over how similar it was to Steven's second device..............
Steven's second device in the video coilnew05.avi looks like the exact same thing as a previous patent from 1993 in France.
Allow me to explain the EXACT similarities in detail, THEN you can decide for yourself.
Here is a description of the device:
--This patented generator is a solid-state generator which uses the nuclear resonant ferromagnetic effect in a cylindrical rod of iron. (BALING WIRE ANYONE???)
--It uses a common iron rod (isotopic number 56) with 3 simple coils wound around it.
--This rod is placed between a U shaped core (soft iron)(A ROD PULS ATTACHED TO A "U" SHAPE EQUALS A COMPLETE CIRCLE/TOROID) for closing the magnetic circuit and thus reducing the magnetic losses(SIMILAR TO A TOROID, SOMETHING STEVEN TOLD US TO LOOK INTO) (see the diagram).
--The inventors claim that if we introduce 105 eV to the iron (isotope 56), its change to the iron isotope 54. The energy generated by this nuclear reaction inside the iron rod will produce an energy gain of 20,000 eV. The energy required for generating the isotopic mutation is produced by a nuclear magnetic resonance effect. The parametric excitation is obtained by the coil #2 acting as the pump.
The energy output is collected by the coil #3 which is able to produce 110-220-380V at 400Hz(THIS COULD PROBABLY BE CHANGED, THE Hz, BASED ON THE SETUP USED).
--The iron rod is used as the main source of energy by isotopic mutation effect, thus, this will provide a simple and cheap source of energy for a long time.
--The inventors claim that this device can be used for building self-powered elecrical power supplies.
Here is the patent abstract:
Abstract of FR2680613
Generator of energy by resonant nuclear ferromagnetism, consisting of a "U"-shaped chassis made of mild steel containing a cylindrical bar made of ferromagnetic fuel rod on which at least 3 induction coils act.(AT LEAST THREE, SO THERE COULD BE MORE)The first coil is an electromagnet(YOU COULD ALSO USE A SMALL PERMANENT MAGNET TO PRODUCE THIS SAME EFFECT AS THE DC BIAS FROM THIS ELECTROMAGNET DOES, HMMM :)), the second is a nuclear magnetic resonance actuator(THE KICK GENERATING WIRE), the third(COLLECTOR COILS) recovering the induction energy present in the bar. Device intended particularly to supply commercially exploitable electrical energy as well as to perform isotopic mutations.
Now, lets look at some of the things that we have seen from the various videos of Steven and his words:
--Steven's device is known, at least the first one, to use baling wire, of which many consist of IRON.
--Steven NEVER SAID he DIDN'T use batteries, only that a battery couldn't do the demonstrations of power his TPU was showing, that doesn't mean a battery wasn't there to provide the frequencies to the IRON,
--Steven said to pay attention to the TOROIDAL structure and that it was IMPORTANT, hmm, just like the device above, absolutely IMPORTANT.
--Steven's device OBVIOUSLY used permanent magnets NEAR the coils, hmm, maybe to simulate the 0.5 Tesla DC field that the electromagnet on COIL #1 of the patent creates?
--Steven's devices came out just a little after the French patent above, i.e. 1993.
--The AC entered into the COIL #2 would be the KICK GENERATING WIRE that produces the nuclear reactions that move through the TPU and are picked up via the COIL #3.
--Steven's second device in particular appear to ONLY HAVE A COUPLE COILS, JUST LIKE THE PICTURE FROM THE FRENCH PATENT.
Again, if I am wrong, at least we got to see another potential for inclusion into the matrix of ideas about Steven's TPU, a win-win situation.
Thanks Tao for bringing this up. There are definate parallels with the Steven Mark's device as you've pointed out.
Have you noticed that the 21Mhz mentioned in the patent is exactly 120 times the 175Khz identified with magnetism ? Interesting huh.
hartiberlin
Hi Bob,
did you try in your experiments,
if you can use the Barkhausen noise spikes
to induce a voltage in other coils ?
Many thanks.
Regards, Stefan.
bob.diroto
Quote from: hartiberlin on July 04, 2006, 08:59:11 AM
Hi Bob,
Many thanks.
Regards, Stefan.
I have this on my list of things to try.
I'll pm you when I have done it. (and will post to the board the results)
I'm concentrating at the moment on getting parts for a pulsing circuit.
I do have to say in the next few weeks my spare time is going to be limited as a project at work moves to the next phase.....
