The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 43 Guests are viewing this topic.
gn0stik
Quote from: giantkiller on September 29, 2006, 05:26:23 PM
All well and good....
But the toroid has an emmission face that points inward towards itself, the center. And that is where the compression comes in.
When you apply a square wave, on the front side of the pulse the magnetic field ramps up, but on the trailing edge, the force slams back to normality exceedingly faster than the up start due to not only the earth's magnetic force but the magnetic force of the compression. Huge back-emp. On the scope you see the current pulse as that happens. Nature abhors a vaccum.
That is the 'Kick', and the harmonic buzzing and the gyroscope leveling effect. Plus the fact that the first lines of flux generated break apart from the center and envelope the unit spherically, more potential built up. Again, on the trailing edge these outer flux lines break, unleashing more power, back to enveloping the toroid and decease through the windings. A sine wave can't produce this effect as great.
It slowly relaxes and looks like the generated freqency. But again, the square wave has infinitely more frequencies and harmonics. All this work is very dependent on how the unit impresses force and vibration to create interference against the earth's magnetic field. Tesla talked about this. 8)
Did you even bother to read it? Honest, I'm absolutely positive you'll be impressed. Everything you are saying agrees with it. Aside from the square wave part. I'm not sure if it specifically spoke about that.
However, as I said, before, it explains a lot about how the TPU interacts with the earth's magnetic field, ideas for frequencies to tune coils to, how to make coils more sensitive to the magnetic field, how they behave when perturbed by strong LOCAL field.. Good data here. I'm not saying we start building magnetometers, but there's a lot we can learn from them. SM's device does the same thing as a magnetometer, but on a MUCH LARGER SCALE. This specific Magnetometer is a proton precession magnetometer, which utilizes hydrogen electron spin for accuracy in detection, it's basically a toroid circumferencially wound around a WATER core.. bizarre.. Most are simple toroidal coils with a secondary wrapped around the outside diameter, with a ferrite core... Some have 4 coils wound vertically, and then have one wound around the diameter... Air core (kinda remenicient of something eh?)...
Again, i'm not suggesting that we completely chase this rabbit, Just use what applies to what we are doing.. Skin it so to speak.. There is useful information here.
I attached another example of a different magnetometer setup, this one is a "fluxgate".
QuoteLet's kick some ass, boys! It's about to get real cool! :)
I agree.
Rich
giantkiller
Marcos,
I listened to the wave!
Dude, You are the man! The ticks are the kicks. Can you pump up the power without killing yourself?
supersam
MARCOS,
just keep playing it and the eventually, if you take your surge protectors out, you will see the kick.  damn and i thought you were getting close.  have you tried turning on the air conditioner. seriously.  the best two ways to get a power surge, "kick", is to either wait or create an electrical high pressure system, such as with lightning, or to upset the flow of electrons, by switching!  does your setup take either one of these into consideration?  most likely, and correct me if i'm wrong, your using a computer system of some sort and the weather is fine.
lol
keep up the good work, i really did think you were about to get the "kick".  it deffinately looked like you had on a harmonic coupling that had a growing wave. ??? ;)
sam
supersam
marcos,
my point exactly.  it does NOT factor in a power surge.  most modern electronic equipment try to block or disrupt power surge, "KICKS" to keep from damageing the stuff we are already paying for. and now you want to recreate it just for free energy.
lol
sam
supersam
tao,
nice graphics.  i think everybody should be taking a look at those:dude!  have you got any coments on what has happened today so far, or, is it tomorrow already?
seems like a fairly active day.  have you seen the shot, Marcos gave us of the 7.8hz, 7.4hz, and the 5kh frequencies combined into a note?
  intereting how the wave started to propogate.
what are your thoughts on that?
glad the MIB hav'nt gotten you,lol
sam
