The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 31 Guests are viewing this topic.
jacob
Quote from: ctglabs on September 30, 2006, 09:33:55 AM
Hi guys,
Can you explain?  I must be stupid.
Thanks,
Dave.
Dave,
Like I said in an earlier post: "Fact is if you operate two resonant LC circuits perpendicularly with a slightly different frequency (and maybe with a  frequency difference of approx. 7.8 hz) you achieve two goals: you create a rotational magnetic field and you combine two out of phase signals into the same magnetic flux which according to SM can yield some interesting results... "
We know that the kicks are obtained by having two frequencies interact with one another. Therefore, operating an LC circuit with one (frequency), and the other LC circuit with another (frequency), we get it all: the rotational field AND the energy wave.
Regards,
Jacob
dutchy1966
Hi everyone,
Does anyone already have clue about what the outer control coil is used for? Could it be that this one is used to induce a small voltage from the earths magnetic field and with that voltage starts the whole process. Are those oscillators in the center of the big device connected to the outer coil or the inner coils?
Then the inner control coils are used to create the radiant energy which in turn is to be picked up and converted by the multistranded collectors.
regards dutchy
jacob
Hi Marco,
Quote from: -[marco]- on September 30, 2006, 09:41:42 AM
so the kicks must be generated with many many windings as in the high voltage transformator for the televinson elektron beam witch writes 256 picturelines @ 50 Hz or so on to the screen.
While there is HV feed into a defection yoke, there is none in a TPU in its rev up phase. Therefore high voltage is not necessary to produce a kick. This kick HAS to be frequency related, meaning an interaction between two different signals.
Jacob
jacob
Quote from: dutchy1966 on September 30, 2006, 10:28:13 AM
Hi everyone,
regards dutchy
Hello Dutchy,
What do you mean by inner control coils and outer control coils? If by outer you refer to the larger diameter windings, these are used in opposite pairs to rotate the field and also probably induce a near to 7.8 HZ standing wave in the collector windings through interaction between the two signals. As for the inner coils, my guess is that they are used to somehow tune out the device if need be to prevent a power surge.
Regards,
Jacob
Mr_Video
dave, the deflection yoke inside a television.... its the driver for the elektronbeam witch writes onto the screen.
its made up of x and y coils so putting up some power on one side will push or pull the truerunning elektronbeam to the other side.
now for the exploding television had to somehow be bad grounded circuit so peaks appear in the yoke witch on one point started to synchronise with shuman freqency and BOOM. ;D
Gentlemen we are getting closer. :)
it also explains all that dust around the high voltage circuit in a tv set.... is all the static energy that hangs around and pulles the dust.
you guys seem to be overlooking the most obvious & most plausable explanation about the exploding TV set......
LIGHTNING !
a direct hit on an outdoor antenna with a million volts & many thousands of amps COULD produce the same result .
