The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
gn0stik
Quote from: ctglabs on October 01, 2006, 06:52:37 AM
Guys,
I had an iron torroid laying around with a bifilar winding on it from something else I was doing.
I fed a different frequency to each one.  You can actually hear a 3rd wave, I do not know how to describe it, but it actually sounds likes it speed up and wizzing around the torroid, I tried to record the sound, but its too high frequency for the mic I think.  I tried a compass but the iron core contains the field.  I know its sounds silly, but this wave speeds up, by istelf, you can clearly hear that (well the simulations told us it would), and you can hear it wizzing round, its quite amazing to experience.  SM said it speeds up byself, if its same frequency out of phase it cannot and will not do this.  So as he says in the video, Frequency1, then frequency2!  It must be two frequencys and they will of course be out of phase anyway which will continually change.
I tried my original TPU but the single core windings must have broken inside as they appear to be open circuit.  I must re-wind.
I also tried that segment coil I wound, no joy with anything on that.
Regards,
Dave.
Sounds promising Dave, Too bad there's a short in your old TPU. It would be interesting to see the field from that with a compass.
As to the second post regarding this experiment, Those spikes you show in the scope shots, what's the duration on them, and how close together do they occur? Is it just once per pulse?
dutchy1966
Quote from: ctglabs on October 01, 2006, 06:40:30 PM
So, we can say Radiant energy is the answer.  So based on what we know, how can it be generated in the TPU.  We know fast rise times can do it and the spikes I saw today from mixing two frequencys were so fast my scope could hardly see them.  Could these be enough/away to release this radiant pulse?
How to get these two frequencys going by themselves in the first place with no input?  External noise to trigger two resonant circuits..?
Regards,
Dave.
Well, going by what Steven has given us so far I would say create many of the spikes you have seen. According to SM this load of littler spikes somehow have to be combined into on big spike (kick). Might it be that this big kick is enough to create a burst of radiant energy?
For now this is how I see the device, most likely, operating.
hartiberlin
Quote from: ctglabs on September 30, 2006, 04:39:04 PM
Tao,
Take a look at the pic attatched.
Firstly we can clearly see bifilar windings as two colours of wire are seen on each coil.  In other pics you can clearly see there are 4 such bifilar windings on the bottom ring.  This can indicate the transistor with base and trigger coils as shown in my previous post, one triggering the next to create rotating field.  Or each winding of the bifilar could have a different frequency and create rotating field that way, or they could counter rotate.
But we can clearly see on the top ring there is no coils, I think the top ring is just part of the "frame" of the device?
Regards,
Dave.
Hi Dave,
you are right,
there are only 2 or 4 coils in the lower ring,
none atthe top ring.
I think these are red copper coils with small diameter
copper wire and around it we have a secondary coil with only about 10 to 20
windings andmuch bigger diameter, which looks black in color.
So could it be the principle TAO has found in this patent to draw energy from
mutating the iron atoms to a different isotope ?
Where could one get this special ? iron material ?
hartiberlin
Hi Dave,
how did you get these small duration spikes exactly ?
How could you light a bulb with it already ?
2. Did you still try, if the coils being put upside down
generate less signals than the other way around in an open space with no metal
nearby ?
Many thanks.
P.S: I am a littlebit behind reading, cause I had other things to do,
will catch up soon.
dean_mcgowan
@gnostik
I was just checking out the videos that a friend referred, sometimes there are little nuggets in there. I am intrigued by the ideas, but certainly not a subscriber to the "Heavens Gate" mentality. Its a bit like being pregnant I think, you don't notice that there are a lot of pregnant people around until you are (or your partner is) pregnant, then all of a sudden it seems like everyone is.. lol and there is some kind of mad baby boom happening around you.
I really do think that we may have to consider the elemental or materails aspect once the general functioning of a device is achieved as I suspect that may play a role in the efficiency of the final product.
Cheers,
Dean
