The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 51 Guests are viewing this topic.
Elvis Oswald
Whatever the source of input this device has... and it has been implied that the source is the "kick" that comes for "free" when a circuit is closed... so we have a source that is not really used - only for the initial "kick", over and over and over...
Then perhaps this is a series LC circuit resonating at the same frequency as the input so that impedance is zero and the output is amplified 100-1000 times - over and over and over?
see this reference...
http://www.allaboutcircuits.com/vol_2/chpt_6/3.html
hartiberlin
Good idea ! This could be, that he has the coil of the LC circuit then on a toroidal core
and the resonating will induce into the secondary also pulses.
The question would then be, why the magnet field would spin up
in frequency ( the compass spinup) ? This would not fit with a fixed
LC resonance circuit....
Elvis Oswald
ty.  :)
I would have no idea how this power is then transformed or delivered to a secondary circuit.  But... it's possible that the physical arrangment of the coils... whether multiple LC circuits or a combination with secondary coils... that the alternating current is rotating around a concentric axis.... thus creating a gyroscopic effect.
Also... don't forget that the power input is said to be small... and so the device is constantly adding that small input to the residual (input minus loss) at each cycle.  This would cause the coils to produce more and more (flux?) and if they are arranged so that it is a roatating field... it would cause the perceived gyroscopic affect to get stronger and stronger until it reached maximum.
The time to stop this motion... the "spin down" also points to an oscillation like in an LC circuit.
Maybe you can answer this - I have heard that you cannot couple a secondary coil to the coil in a LC or "tank" circuit.  Is this true? If it is, then we are still way behind the curve on how this device works.
hartiberlin
P.S: I have searched back and forth GOOGLE for any reference of the earth magnet field
for instant bigger current when switching on ( Einschaltstrom)
but have not yet found anything related to the earth magnetic field.
So until someone can scan these valve book pages we will be still
in the dark how this effect is working and how it can be seen in an experiment.
P.S: the experiment with the cable and the battery:
There you probably just see, that coil loops repell each self against
each other...
So if you lay a longer wire into a coil onto the floor and energize this cable
the loops will just repell each other, but just only due to their
own magnet fields repelling each other loop...
Stefan.
Elvis Oswald
parallel wires with current flowing in the same direction will attract.... reverse the current in one of the wires and they repell.
I'm not sure where the "kick" comes from... but flip the switch on a big DC generator and you will see the glow.
