300ccm 4-stroke Generator running on 8 liters of HHO
Started by woodpecker, March 30, 2009, 01:07:23 AM
Walter Hofmann
hi all,
just my two cents, the first one who has worked this cell out was tero ranta after inspiration from bob boyse, just to clear this up. this must be here somewhere in the forum stefan knows probably where.
I also have running a 1 Kw generator on a version of this cell just with 13 plates = two times 6 with the middle on positive and the two outside on negative 12V.
greetings
walt
Quote from: Spewing on April 01, 2009, 02:09:15 AM
@Farrah day, There use to be a video of the guy's that claimed to have invented the drycell at www.energybuilders.net, Perhaps its still there now.
Mark69
@ Wood,
There are timing delay devices available for purchase through automotive performance companies, such as Summit Racing and Jegs. (www.summitracing.com   www.jegs.com).  My only concern is that they may not have one to work exactly for your application, since your generator is most likely only one or two cylinders.  The smallest they may have is for a four cylinder but maybe with someone who know electronics, they could make it work.  Or they may have one that could work.  Since I do not know much about generators and specifically the type you have, I am guessing it is a set timing that doesn't have any adjustments.  But it is possible to get an adjust able delay box to work, we just need someone who has this expertise to help out.
Mark
Farrah Day
Woody, I would imagine that the ignition system on a small genny must be very basic. If it's only a one cylinder affair then it will obviously not even have a distributor.
I've never even looked closely at a genny, but I would have thought there would be a fairly simple way to modify the ignition system so that fires later. Might just need a bit of considered improvisation.
Good luck with it.
Farrah Day
"It's what you learn after you know it all that counts"
woodpecker
@walter, aha, from this corner it was comming, very interesting, you know, when i made my first cell, i had no plan or design,  i had only a shor thandycam video where i could see such a cell from outside, and i had no idea from hum it originally was. So thank you for this information!
You have a Generator too, running with the gas! Maybe you could do a Video too. I think it is important that as much people as possible show their experiments now.
@Farrah Day, Mark, for the moment i will just try out my selve made Ignition, with the Hall on the right place. I now sombody who is experienced in bikes and carts who can help me a little bit.
woodpecker
pese
@woodpeacker
Das Ding liefert schon mal das Gas soviel , wie es auch verbraucht ??
ist das richtig ??
Dann haben Sie mindest dieselbe Energie als OVERUNITY !!
Bemerkt das niemand.?
Ist doch ganz einfach...
Sie erzeugen MINDEST nochmal 1000 Watt Wärme
und kein schädliches Abgas.
Gratuliere.
(Wie sieht es aus mit 5 Zellen a 240Volt DC? Ist doch
vielleicht einfacher...)
Pese
Translation.
YIU HAVE OVERUNITY , also if you not find additionally electric power!
Why?
Because yout generator work with losses !!
If they produce 1000 Watt  (to create the Gas) you produce
(possibly?) about 50% losses that turned to heat.
IF the Implosion (explosion?) produce heat.
So you produce additionalle 1000Watt heat (without dangerous exaust).
If so . that is great
Pese
