is it possible to mimic a homopolar motor with permanentmagnets?
Started by Low-Q, March 30, 2009, 06:02:23 PM
Low-Q
The homopolar motor works because there is a circular magnetic field crossing the flux in the magnet. Is it possible to mimic this circular magnetic field with permanentmagnets?
I'll let the idea be up to you guys to discuss. I will ofcourse attend the discussion, and test ideas as they come up :)
Br.
Vidar
mr_bojangles
to specify, using a circular magnetic field of a permanent magnet to induce cross flux and rotation on a different permanent magnet?
hmmm it would be quite different from mr faradays first homopolar generator, not at all a bad thing
unless maybe your referring to the actual "homopolar" aspect, meaning a current or induced output of only one pole (conventional homopolar) and attempting to achieve this not using a conductor as a rotor but another perpendicular magnetic field to create the motion
have to think of this a bit
you have a few gears turning in my head, we'l see how it plays out
i see youve given it some thought and im curious as to what you have come up with
until next time
"If at first you don't succeed, try, try again. Then quit. There's no point in being a damn fool about it."
-WC Fields
powercat
gravityblock
I had this same thought a few days ago.  I would like to know the answer to this also.  Even if the idea doesn't work, it is creative thinking......and we need creative ideas if we are to achieve OU.
Pirate88179
http://www.metacafe.com/watch/1236322/homopolar_magnet_motor/
Above is a video I made of a homopolar motor.  somewhere on the earth battery topic, Localjoe came up with a diagram on how to tap high voltage off of this device by using a simple coil around the rotating shaft.  It will take a while but I will try to dig it up.  He said something about it taking advantage of the already rotating magnetic field so I think this might be related.
