Steven Marks Tube Power Supply
Started by wattsup, March 31, 2009, 01:38:50 AM
wings
Quote from: otto on March 31, 2009, 07:56:05 AM
Hello all,
@wattsup
thanks.
I can only say that Im happy to share my work because maybe, just maybe, someone of you will have success. As posted before, I dont have the needed transformer and about caps with low ESR I can only dream!!!
So, people, use my informations and finally start to work.
Showing you my problems I ONLY wanted to say that if you wait for me to do the job it will take a time until I have solved this problems.
Otto
low esr in flash camera
Bruce_TPU
The tube amp starts a chain reaction (catalyst)
The secret is what is taking place in the collectors.
A tube AMP is needed for each frequency.  When unit is switched over to all SS, the SS is made to mimic the frequency reproduction of a tube AMP.
Without a tube AMP, actually three of them, you will never see catalyst, even with the right circuit potential and litz, which no one here gets yet, because they won't look at the frequency's journey inside of the loop collector.
Oh, P.S.  The secret is not found in HV either.  It is found in HOW DIFFERENT frequency's react with one another.  Nothing that can't be found with some good research. And then how they react traveling, opposing one another.  You can start with GK's Heterodyne thread, CTG Labs transformer experiment, and then go to my thread discussing lightning and then move on the circuit potential, while at the same time, re reading and studying everything SM said!  LOL
gyulasun
Quote from: otto on March 31, 2009, 02:07:43 AM
... into a 100 microfarad or so electrolytic cap with low ESR (??) and another 0,01 in paralel,
Hi Otto,
If you question marked the ESR what it may be, then it is the short form of Equivalent Series Resistance of  (mainly)  electrolytic capacitors. It simply means how lossy they are, low ESR means much less loss i.e. heat would develop inside the body of the capacitor.  On the other hand, with low ESR a capacitor can supply higher peak load current than a normal because the lower inner resistance (which is also frequency dependent) is less of the limiting factor.
Electrolytic capacitors with low ESR values normally cost higher than 'normal' electrolytic caps of otherwise same ratings.
There are off-the-shelf  ESR tester instruments, here is a home-made-able practical circuit if anyone is more interested: http://members.shaw.ca/swstuff/esrmeter.html
rgds, Gyula
EDIT  I noticed wattsup mentioned in the meantime what ESR is, ok.
Grumpy
Quote from: otto on March 31, 2009, 06:58:37 AM
Hello all,
yes, Im also thinking how SM made this with SS but I have first to see the magic with my tubes so I can really understand how and why.
Now, lets think what we know:
the TPU output has sinewaves with kicks on top of them.
This means we need kicks and sine waves in our TPUs. The kicks are made in our well known manner with MOSFETs.
Now the sines: when I connect 1 end of my high voltage to the copper core then I have the needed sine waves and depending on the frequencies used I have the needed TPU output but still no "magic" to say so.
As always Im in a big trouble. My heating transformer has a 6,3V heating and the 5U4 needs only 5V. The next is that we MAYBE need 500V - 0 - 500V as the plate voltage and my transformer delivers me only 300V - 0 - 300V.
Any ideas? Dont say that I should surch in junkyards because this is impossible.
A hand made transformer? Yeeeees, but money, money, money.....ha,ha.
Otto
How do you think the TPU works?  What is the basic mechanism that makes it work?
        -Frank Edwards
Grumpy
Quote from: Bruce_TPU on March 31, 2009, 08:57:15 AM
The "collector" is just a piece of wire shorted by a resistance.
The secret is the effect that HV has on the aether.
        -Frank Edwards
