Steven Marks Tube Power Supply
Started by wattsup, March 31, 2009, 01:38:50 AM
Grumpy
Quote from: Chef on March 31, 2009, 09:42:09 AM
It's very easy. You just haveto turn it ON, and it works. :P
Or maybe, but I am not sure:
"X,Y,Z = 20 MHz
A = 60 MHz
TIME IT+PULSE IT+ROTATE IT+COLLECT IT:      Spherical Aether Shock waves"
8)
Oh yeah!  That's right!   ;D
        -Frank Edwards
giantkiller
Tubes present the ION cloud and HV.
Moray states microwatts using copper.
Bolt: 'You can transmit a longitudinal wave through an ion cloud unresisted'.
'To pump scalar its 90 degrees offset to M field so coils are perendicular.'
The loop must made to appear massive. Effective aperture.
SM
"I have designed some amps using MOSFET , etc.
which sound very much like tube amps.
However when I want to design a new amp I always start with tubes and when I get them perfected I move on the MOSFETS.."
The reason is the HARMONICS that a tube amp NATURALLY puts out.  OR a SS built amp that sounds like a tube amp, in other words, has the SAME HARMONIC components.  They have developed some of these now, I have read about them.  But I would still suggest using VHF Triodes for color television, three of them to start with.  Once you understand what is transpiring within the collectors, the creation of hundreds of frequency's, combining to one, you understand why the tubes are needed to build a SM style Power Unit.
"REMEMBER, all of that noise and hash in your solid state amplifier is in the output signal !
Now tell me? What do you think is happening inside the extremely sensitive torrid generator
when you use solid state devices to attempt to create the required precise control frequencies to make catalyst and produce power???
By the way, your Solid State amplifier generates so much noise that if you measure the mains wiring you can see noise from YOUR amplifier actually getting back through the transformer and into the mains input wiring!!!
Understand what perfect frequency is."
That is why Bolt suggested building the ad826 class 'A' amp. I did. I got results. It has excellant 'Signal to noise ratio'.
--giantkiller.
Grumpy
SM could have used a tube oscillator of some sort fed through the saturable reactors.  With their high impedance, he probably did not have to worry about directional biasing, as it could not go back through the tube.
If this is the case, you direct the field and use SS devices.  Of course you would never know this if you had not started with tubes.
Yep.  Damn good reason to start with tubes.
        -Frank Edwards
otto
Hello all,
@Grumpy
I started to wright how I see a working TPU but it has no sence because I would need a lot of guessings.
What I want is to start a "race" in my collectors. Do do this I have to measure the lenght of my collectors. I want to tap into this collectors at exact points. In this way have the particles the lowest speed on the start point until they arrive to the 2. point where another frequency is added. This 2 frequencies are then travelling to the 3. point in the collectors where a 3. frequencie is added....when we have a real race in our collectors then we have done a very good job because then we "only" have to use our controls.
I will try to start such a race with 12V from the power supply, then 24V, then with my loved 5U4 tube.
I want first to use 12V because Im learning and I want to see the differencies between 12V, 24V and a tube.
Yesterday I had luck and removed 4 turns from my heating transformer so I have now 5,8V ( without a load) for the heating of my 5U4 tube. This was a f...g job not to damage the other turns of this heating coil.
Otto
AhuraMazda
I thought I do a little reseach and see what I can find about tubes.
There are a lot of fad stuff because of marketting of valve amplifiers. Just a lot of hype.
However, I have come across a mine of useful information at:
http://www.clarisonus.com/Archives/
I propose you should copy it all.
Please come back and share any usfull information which might light our path to making the TPU.
