Steven Marks Tube Power Supply
Started by wattsup, March 31, 2009, 01:38:50 AM
otto
Hello all,
@gyulasun
there is no recharging effect because I have charged this cap the last time at Saturday, shorted it a lot of times and I see always the charging effect. There is nothing to rearrange inside this cap.
But I saw that this works only with my 50 + 50uF/450V cap. Its a big aluminium cap. I tried a lot of other caps without success.
I found the Tesla patent I surched: Utiltzation of Radiant Energy NO. 685 957
I think I have this effect. Maybe I saw this schematic with a detector diode between the plate in the air and the cap??
Otto
EMdevices
great lecture !!
An interesting free energy machine using electrostatic fields, which was patented,  was the Hyde motor.   Just like in the lecture, the energy is  1/2 e E^2  x volume between the plates,  and Hyde includes another plate inbetween the existing plates of a capacitor and one of the new two capacitors is used in an external circuit so it can dump it's energy, then the plate that was inserted is removed, and the other original plate still has it's charge on it, and it attracts new charges on the other plate that now is unshielded.   The trick?  removed the middle plate sideways, so his whole assembly is in a rotating sort of an arangment.
anyway, that's what came to mind when I saw this lecture,  made me remember my classes I had in electromagnetics years ago.
EM
pauldude000
QUESTION:
Why use a tube to rectify a silicon rectified voltage?
ANSWER:
Simple, as a highly efficient voltage smoothing device.
Put an AC signal through a bridge and scope it. You will soon see what I am talking about. Noisy DC.
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
BEP
Quote from: pauldude000 on May 02, 2009, 02:48:18 AM
QUESTION:
ANSWER:
Paul Andrulis
I've been waiting a long time to see that question posed about that SM comment.
Your answer sounds like it may be partially correct. Cleanup of the signal? Probably. I think that statement was more to make us look at the fact that the emissions of the heater are added to the anode and what happens when that goes on.
Voltage of the heater added to the plate.....
Increased velocity ('voltage' if you like) of the circuit current....
