Thanks to ALL for your help!!
how the major systems on a pleiadian saucer, work.
Started by nitinnun, April 01, 2009, 10:36:07 PM
nitinnun
---artificial gravity---:
the outside of the saucer,
is charged with thousands and thousands of volts.
the top of the saucer, is positively charged.
the bottom of the saucer, is negatively charged.
electrons do not like to turn corners.
so the narrow rim on the middle of the saucer, keeps the 2 charges sepperate.
just like a capacitor !
the metal hull, is wrapped around what can only be called a giant mushroom cap.
this giant mushroom cap, is polymer-like in its tissue.
and has been smeared in resin (gorilla glue !), to make it immune to rot and wear.
the giant mushroom cap, places a vast amount of electrical resistance, between the 2 charges.
also preventing the 2 charges, from discharging.
"magnetic current", flows from positive to negative.
gravity on our planet, is really magnetic current flowing from the positive ionosphere, to the negative ground.
so the 2 charges on the saucers hull, cause downward gravity, within the hull !
allowing the passengers to live normally, in the saucer.
---radiation/inertia/thermal protection---:
the powerful magnetic field of the hull,
blocks radiation,
inertia,
and thermal energy.
protecting the passengers from 7 shades of death, as they travel through space.
the mostly aluminum hull, also has less electrical resistance, than the mushroom cap interior of the ship.
so all forms of energy tend to travel through the metal hull, and NOT through the mushroom cap interior.
this works EXACTLY like the aluminum covered bubble wrap insulation, that you can buy at the hardware store.
and it blocks whatever radiation, is not stopped by the powerful magnetic field.
---primary upwards propulsion---:
has a large bump on it.
this large bump causes the top,
to have more surface area,
than the bottom.
the larger surface area on the top,
allows the top to hold a stranger magnetic charge,
than the bottom.
when 2 charges are unequal,
there is ALWAYS kinetic movement,
towards the stronger charge.
this causes the entire saucer, to lift upwards !
upwards, in the direction of that bump.
to lower the saucer to the ground,
they simply reduce the charge in the hull.
reducing its upwards thrust.
---primary horizontal/sidewarys propulsion---:
what we call "the tesla flying machine", is used for horizontal/sideways propulsion.
it is nothing but 4 spinning weights.
all 4 weights spin in "the same direction"
causing massive kinetic force, in that direction.
like this:
      W
---> ---> kinetic force --->
      W
this kinetic force, is anchored to NOTHING BUT THE SHIPS HULL.
so the ship can move in any direction, regardless of the environment outside of the ship.
it can even be used, to keep the saucer positioned firmly in one place.
even if a 200 mile an hour wind is blowing on the saucer, from one angle.
---primary power source---:
there are 2 spinning disks, inside the saucer.
one disk spins clockwise.
the other disk spins counter-clockwise.
these 2 spinning disks, work EXACTLY like a wimhurst machine.
as far as i can tell, the wimhurst machine gets this energy, from the magnetic energy that is found in every square inch of the universe.
the wimhurst polarizes this universal energy,
into a positive charge (in the clockwise spinning disk),
and into a negative charge (in the counter-clockwise spinning disk).
the 2 magnetic charges stored in the disks, are then excited with a frequency.
this excitement causes MUCH more voltage and amperage, to be genetated.
i think this frequency excitement, is EXACTLY like an overunity torroid.
but instead of having the kicker coils wrapped around a big primary coil,
they have the kicker coils wrapped around the 2 spinning disks.
---primary stabilizers---:
the clockwise spinning disk,
and the counter-clockwise spinning disk,
stabilize the saucer.
the kinetic movement of the spinning disks,
prevents the saucer from flipping over.
yet causes little resistance, to moving horizontally.
the saucer uses the tesla flying machines, to move horizontally.
but adjusts the charge in the metal hull, to move vertically.
---where i got this information---:
i got this information,
by applying my FEELINGS,
to technological information.
my feelings made connections, between pieces of information.
my feelings, allowed me to see the coherency.
my feelings, allowed me to educated guess my way, to the truth.
my effort was 2/3 my feelings,
and 1/3 logic.
going extreme on logic, is ultimately wasteful.
because feeling covers the gaping holes, that thinking misses.
Michelinho
Hi nitinnun,
How many of those have you built? I have seen many designs but never seen one that flies.
The Titanic was one of the best built ship (in 1912) to ever sail the sea but it sank anyway.
Take care,
Michel
nitinnun
i have not built any of the systems.
primarily because i am profoundly lazy.
primarily because i have received too many demotivating, 2 cent remarks, from the peanut gallery.
i KNOW how to build the ******* saucer.
that puts me countless peanut galleries ahead, of 90 something percent of the population.
stevensrd1
gravityblock
@nitinnun
The UFO's use a vacuum system within a planets atmosphere.  They create a vacuum in the direction of travel. If there is low pressure on one side, the other side is subject to the full atmospheric pressure.   With an atmospheric pressure of 1.033 kg. per sq. cm. we can calculate that the force operating on a saucer of 20 m. diameter is equal to 3,278,272.8 kg.
Cathode rays have the strange property of decomposing the atmosphere through which they pass. Under the action of these rays, the elements of the atmosphere revert to their etheric state. In addition to this, the cathode rays intersect the anode rays at an angle of 45 degrees. This is achieved by using high voltage and current.  If they wish to go very fast, they use an absolute vacuum, and move through space in a flash. At other times, they use a semi-vacuum, and they will move more slowly. The intensity of the vacuum is proportional to the current used and is controlled by a rheostat. If they want to follow an undulating course, then they use a pulsing current.
Outside the planet's atmosphere, they use a different method.  They make there own etheric fluid inside the saucer, which differs from the terrestrial ether envelope of the planet, and the magnetic field of the planet no longer affects the saucer, and they can enjoy complete freedom of movement.
By changing the polarity of the artificial etheric fluid, so as to oppose that of the planet, then they are repelled from the planet at a speed corresponding to the difference in polarity between the saucer and the planet.  Also, by producing an artificial etheric fluid similar to the planet they wish to travel to, then they will be attracted to the planet at a tremendous speed.
GB
