Sjack Abeling Gravity Wheel and the Worlds first Weight Power Plant
Started by AquariuZ, April 03, 2009, 01:17:07 PM
Omnibus
@ruggero,
Now, upon trying to import it, the message that pops up reads: "Could not complete your request because no understandable objects were found in the document. This document may not contain any objects that Working Model understands",
0c
Quote from: AquariuZ on April 17, 2009, 09:34:53 PM
Ok a quick one done. Crude wm2d model attached.
It fails (sorry) because the wheel needs to spin in such a rate to bring the ball back up that on the downpath the ball does not impose a downward force on the wheel (moves faster than gravitational acceleration of the falling balls)
Hence it will slow down to a point where the wheel is no longer able to bring the balls back up.
In other words, the balls cannot keep the wheel spinning at such a rate as is required to bring even one back up.
http://www.overunity.com/index.php?topic=7150.msg172368#msg172368
AquariuZ, there is a slight modification to my previous animation I would like to see modelled. It should be fairly trivial. I just want to see if this way manages to conserve enough momentum that the balls can keep up with the wheel. If it looks interesting, could you also post a video?
Thanks,
0c
Omnibus
AquariuZ
Sorry, count me out for the next few weeks.
I have studying to do... Serious studying...
Check my posts in Bendini and Magnet systems in relation with ECE which basically explains where energy from the "vacuum" comes from.
I must completely understand all this before I go on like a headless chicken.
http://aias.us
I know, I know, you cannot have it both ways, now I wish I had studied.
