Sjack Abeling Gravity Wheel and the Worlds first Weight Power Plant
Started by AquariuZ, April 03, 2009, 01:17:07 PM
0 Members and 52 Guests are viewing this topic.
Cloxxki
Quote from: eisenficker2000 on May 09, 2009, 04:56:00 PM
@Cloxxki the slots are wider then the 3 mm axle of the "Diabolo" weights. The weights rotate and are pushed/rolled outside by that. Yes there is friction, but as there is no load on the wheel, it is free running, it should be overcome.
Thanks for the drawing, it's closer to what I meant to recommend that I expected from the picture.
I meant the wider slot suggestion allow the weight to perhaps roll up the ramp further before this momentum is use to accelerate the wheel. To use speed as long as it's there.
Perhaps my idea of a folding rod has some merit after all, to get away from the two weights always being in one line with the axle. At least, if your setup cannot be made to work as hoped.
The top ramp might be converting (I can't calculate or simulate that unfortunately) the last bit of momentum all in height. If the hump was just lowered and flattened some, perhaps more speed would be carried. With any speed almost, I'm pretty sure the end of the slow would be found well before dropping below the axle again.
If anyone can simulate this or easily substitute the slotted wheel plates, I'd wonder about a mimimalist hockey stick hook, with the remainder of the stick wider especially past the hook, and curved, outside pointing in the wheel's rotation direction.
In you setup, the weight *seems* to start pushing the wheel again pretty much right after being unhooked, or am I getting that wrong?
spinner
Quote from: hansvonlieven on May 09, 2009, 04:27:38 PM
A balanced wheel once put in motion will spin forever if there is no force acting against it. ie. in an ideal or perfect system.
Hans von Lieven
Of course! And the pendulum under ideal conditions would work perpetually, too. And they would both be a 3rd td law breakers, just like the superconducting ring with induced current.
Once started, it would "go forever", perpetually... (never mind the energy needed for start, or maintaining the conditions for performing (high vacuum, ZeroF bearings, cryo-cooling, ..))
Hell, even (some) "overbalanced" concepts would work if there was no friction, air/bearing/.. resistance, etc...
Sadly, such devices (or perpetuum mobiles of the third kind) would not be very useful....
As soon as you tap into such a source, it would stop (sooner or later, depending how much energy one put in initially...)
I'm a bit old-fashioned, so I prefer the 1st law Perpetuum mobiles... The ones which should produce eternal/surplus/useful work (or, create energy).... ;D
Thanks to guys like Mondrasek and Hans.. I admire your patience and persistence explaining things, especially when you try to answer the posts like this...
Center of mass is persistently to the right of the axis of rotation according to the wm2d, therefore, this must be a perpetuum mobile if we are to believe the program....
The decisive factor proving perpetuum mobile is the observed persistent discrepancy in the position of the axis of rotation and the center of mass....
The program seems to be correct on that and it's proving unequivocally this device is a perpetuum mobile, at least in the ideal case. I've repeated this multiple times and I'm saying it again because, unfortunately, you don't want to hear it....
If these centers are correctly placed by the program (as they seem to be) at the different moments of turning of the wheel and if they always stay sideways to one another at any position of the wheel, that's a definitive proof that the device is a perpetuum mobile. Interestingly, that's exactly what's observed with the model of Abeling's device.
The conclusion is that the model of Abeling's rig is a perpetuum mobile at least in the ideal case....
One also doesn't need the ramp. Just the slotted wheel and the spheres, positioned where they would be if the ramp were present, is enough for the conclusion (the ramp, by the way is very light and practically doesn't contribute to the calculation of the center of mass). This can be repeated for different positions of the wheel within its full turn only to observe that the center of mass is positioned always sideways to the pivot. That clearly is a proof that the device is a perpetuum mobile. Simple but categorical criterion....
This has to be studied more now that we know that perpetuum mobile is possible in principle....
No, no, we're discussing an ideal situation. No resistance, only masses and gravity. It's a perpetuum mobile, no doubt about that....
Reality of perpetuum mobile has already been proven beyond doubt theoretically. What remains now is to see it as a working model. I don't doubt that it has been done in the past but many fall for the propaganda and repeat its mantra that it hasn't been done before. That's just propaganda. It has and that can be confirmed at once theoretically....
For a device such as the one we're discussing to be a perpetuum mobile the mass must be off center at all positions of the wheel making it always a self-starter. Such self-starter won't work only due to poor engineering....
Ah, Omnibus.... Fascinating...
Cheers!
"Ex nihilo nihil"
Omnibus
Hans von Lieven
No, I said what the condition is. A balanced wheel when not put in motion not only will not spin forever but will not spin at all. Unbalanced wheel, on the other hand, even if not set in motion will spin forever when let go from a standstill if correctly engineered, let alone if the conditions are ideal.
0c
Quote from: Omnibus on May 09, 2009, 06:38:52 PM
Seems to me an "unbalanced wheel" will seek the position of maximum entropy, which just happens to be "balanced". Once that is achieved, there is no more motion.
... according to conventional thought, anyway
Omnibus
Quote from: 0c on May 09, 2009, 06:47:46 PM
Learn first what entropy means before attempting to use such big words.
