Sjack Abeling Gravity Wheel and the Worlds first Weight Power Plant
Started by AquariuZ, April 03, 2009, 01:17:07 PM
Grimer
Quote from: NathanCoppedge on August 05, 2019, 03:28:36 PM
IF YOU ALL ARE NOT BOTS, YOU'RE DOING AN AWFULLY GOOD JOB AT PRETENDING.
YOU SOUND LIKE ALL THE SAD AND CONFUSED VOICES I SEE ON THIS FORUM.
I'm not a BOT. But then if I was I suppose I would say that wouldn't I.  ;D
I'm glad to see you are only 36. I think many significant contributors to this thread
must have died since 2009. Bit of a problem since I want to quote one of them (spinner)
and hope for a reply.
Who is she that cometh forth as the morning rising  -  Fair as the moon. Bright as the sun  -  Terrible as an army set in battle array.
Grimer
From Dumbbels on incline...
« Reply #1 on: Today at 03:03:58 »
[size=0.85em]
Quote from: iacob alex on 22-02-2010, 18:26:26... ...may be,a simple puzzle question.
    So,we have an inclined plane and a dumbbells (see weightlifting sport...).
    It can roll down,freely,on an inclined plane ,between two gravitational levels,one way or another :
      -rolling on the weight disks (plates ).
      -rolling on the connecting rod (handle).
      -....rolling on an ever increasing thin ("slim" ) handle,until a simple straight line.
    Now,it seems that,the rotational inertia is different...namely,ceaseless increasing ?!
          All the best! / Alex
Well done Alex. You've found the connection between the Keenie wheel and the Abeling wheel.
Not only that but there's a connection between the Keenie and the WhipMag, i.e. transfer from
an outer perimeter to an inner perimeter, from GW to AGW (gearwheel to anti-gearwheel) that
figured so prominently in the Steorn forum.
I suppose you could say that they found the way to weaponize the tippee top where EG is tranduced in NG.The Tippee is a one way street however. Keenie and Sjack have found a way to cycle it. Keenie was reputed to be some kind of descendent of Bessler so that figures.I always thought that Bessler's covering the end of his weights was to hide a hole through the weight but it now looks as though it was to hide an axle. To be fair to him he did give a big clue on his toys page, i.e. the top.
Grimer
Quote from: AquariuZ on April 03, 2009, 01:17:07 PM
Greetings.
I was surprised to see a search on Abeling receiving "0" hits.
So, long overdue as he is about to go ballistic. (I think)
In November of 2007, an unknown dutch inventor made the rather outlandish claim he had found a way to rotate and accelerate a large wheel by using twin weights and earths gravity as only propulsion. At the time this was merely ruled a hoax.
See the dutch media (local) coverage here: Noord TV Report on Abeling device Edit: added Broli´s version with subs
After that it has been very quiet around Sjack, until a few months back he created a company Abeling Beheer B.V. and started a website which explains his intentions:
"The construction of the first Weight Power Plant is expected in May 2009. The location for the construction of the first Weight Power Plant is probably going to be the province of Groningen, the Netherlands."
and
"The Fall and Lift control system. The invention of the "Fall and Lift control system" was done towards the end of 2006. The system transports, controls and transmits mass/weight to (for instance) a drive shaft. This system was the foundation for a machine that can work on weights/mass only, without adding any form of energy. It's purpose is to drive other objects."
Abeling claims he now partners with reputable businesses like Henkel and has all the approvals needed to go ahead with the project.
Link to the bi-lingual webpage: http://mooieenergie.nl
He appears to be a cool customer, not at all media hungry, and has quietly filed his patents, raised capital and signed partner agreements.
Time will tell if he is 100% legit, his claim is that he will be able to provide power to the general public with at least a 50% discount against current regular provider rates. I think that still is too high, 95% would be better.
My questions to all in here are:
1) What do you think?
2) Have you heard anything about this?
3) If this is a "scam" why pursue it further now that he has all he needs?
My thoughts are that he truly has found a way to generate acceleration using weights and gravity only, or at least HE is 100% convinced.
I have sent him a message of encouragement, warning and a plea for full publication as soon as possible.
The above is the very first post in this Sjack Abeling Gravity Wheel thread. As you can see SA uses "twin weights",
a dumbbell in other words, two weights on one axle in contrast to Keenie who uses one weight on two axles, one
each side of the weight.
Grimer
I am constructing a kinetic strain microscope in order to magnify induced micro kinetic strain to macro kinetic strain.
The figure below shows the main frame consisting of a wheel mounted on a tower.
Micro kinetic strain will be induced in the tower by rotation of a 360° pendulum bob attached to the periphery of the wheel.
Kinetic strain magnification from micro to macro will be achieved by employing of four additional wheels.
Grimer
Here is a screen grab of the Kinetic Strain Microscope  with the four "lenses" (wheels  ;D ) in place.
mp4.s of the KSM in action will follow.
