Sjack Abeling Gravity Wheel and the Worlds first Weight Power Plant
Started by AquariuZ, April 03, 2009, 01:17:07 PM
0 Members and 66 Guests are viewing this topic.
CLaNZeR
Knocked up a Bhaskara's Indian Wheel today. I know it is meant to have lots of little ball bearings, which I have to order but for now using a couple of small bearings in each slot.
Got some magnet ideas I want to try with it when it is mounted.
Off to make the base and uprights and will start a new thread to cover progress if any LOL
Cheers
Sean.
http://www.overunity.org.uk
mondrasek
Quote from: Omnibus on April 11, 2009, 01:23:16 PM
@mondrasek,
Thanks a lot. However, if that's freewheeling, then it seems to work just fine, unless there's still someting hidden which acts as a motor. Can you check it out? Thanks. (see attached)
Omni, that is messed up.  What you posted is NOT the same file that I posted.  When I open your attachment the balls are in different locations and there is an immediate collision error.  Did you change something or play with it before sending it back?
I downloaded what I had posted and it was fine.  I am attaching it again as a different file.  Maybe it became corrupt in download to you?  Or else it has to do with the version of WM2D you have vs. what I have?
M.
Omnibus
@mondrasek,
Yes, I moved one ball up and put it on the first upper empty groove. This is the starting position which will cause the wheel to turn clockwise. That's the only thing I changed.
persume
AquariuZ, question, how did you know that the white circle was the axle?
Omnibus
Quote from: persume on April 11, 2009, 01:51:57 PM
Sure, you know the post where you asked aquariuz if he was a fellow traveler following a star in a desert for 40 days, since he had the alpha and omega in his name. That was you wasn't it?
No, you must be confusing me with someone else. Sorry.
