Sjack Abeling Gravity Wheel and the Worlds first Weight Power Plant
Started by AquariuZ, April 03, 2009, 01:17:07 PM
AquariuZ
Quote from: broli on April 03, 2009, 03:09:08 PM
Oke I went through the trouble of adding subtitles to the video so other can understand it. Even though little of use is said.
http://www.youtube.com/watch?v=A_0kYz4LhHw
Well done Broli, I wasn´t aware of the fact you are dutch too..
Thanks
Quote from: AquariuZ on April 03, 2009, 05:18:00 PM
Thanks
Thanks, and I'm not dutch  ;).
hartiberlin
Many thanks for the translation Broli.
Looks very interesting.
But it already sucks, that he wants first to patent it.
Probably the delay comes from the patent process and I guess
he will not get any patent on it,cause it will be stamped Perpetual Motion Machine,
which will not get him any patent.
So it would be much wiser just to publish it all freely and make
money with selling books about the invention.
Regards, Stefan.
AquariuZ
Quote from: broli on April 03, 2009, 05:24:01 PM
Which makes it even more impressive...  ;D
One thing though: at 01:09 he says:
"Deze ontdekking had in mijn ogen 200 jaar geleden of misschien al eerder plaats kunnen vinden"
Which translates to:
"This discovery could have been made 200 years ago or maybe even earlier"
Not to:
"Some 200 years ago this invention has been found as well"
Just to be exact... I have modified my initial post to refer to your posting, thanks again.
AquariuZ
Quote from: hartiberlin on April 03, 2009, 05:36:20 PM
Regards, Stefan.
From what I understood he is patenting several things, one of them being the "Fall and Lift control system"...
QuoteWith the development of the "Dual Lift System" in 2008, a disturbance in the system's balance was removed by adjusting the trajectory of the bodies in the system. This made it possible to produce a system with the following advantages:
      Placement below the ground / sealevel
      Technically easy to understand
    * Independent of any energy source
    * Versatile
    * Reliable, manageable
    * Multiple units can be linked
Some applications for this system:
    * Generators
    * Driving systems (e.g. for ships)
    * Transport systems  (e.g. for water)
    * Weight Power Plant
The current objective is to produce power/energy with a new company by building and managing Weight Power Plants.
The Weight Power Plants will be located in closed bunkers wherever power is needed. It is easy to adapt the output of the system to local needs. States, cities and towns can all have their own power plant.
The advantages of this system are:
    * No air- or waterpolution
    * No horizon polution: placement undergrond possible
    * No disturbing noise
    * No blackouts during maintenance
    * Safe
From what I understand his intentions are indeed to release the complete theory, I would be highly surprised if he would not release it because of patent failure, seeing as he already secured several. (need to research to find them in which case I wil post them).
Progress in launching the Weight Power Plant:
    * We have permission to construct and exploit Weight Power Plants in The Netherlands. We can use the existing infrastructure.
    * There is foreign interest in the Weight Power Plant and the watermanagement of Sjack Abeling .
   * Patents have been filed or are pending.
    * Applied techniques are currently being tested at Henkel's.
    * A test system is being prepared.
How can they deny him a patent if the thing works? He should go ahead anyway as he appearantly has convinced a legion of partners and is on the eve of building his first plant in Groningen.
