Sjack Abeling Gravity Wheel and the Worlds first Weight Power Plant
Started by AquariuZ, April 03, 2009, 01:17:07 PM
Cherryman
If you ad the rails you will get this , principle. I tested that...    Sjack has to have something else added...  ???
http://www.youtube.com/watch?v=GBygA2vOHx4&feature=channel_page
I
AquariuZ
(cont)
                  (12)
         7. Conversion unit according to conclusion 6,with the feature, that the or all guiding
      tracks show a hockey stick pattern.
5         8. Conversion unit according to conclusion 6,with the feature, that the or all guiding
      tracks show a smooth flowing curvature over its entire lenght.
         9. Conversion unit according to one of conclusions 5 to 8,with the feature, that the
      or all guiding tracks have at least a partially serrated surface.
10         10. Conversion unit according to one of conclusions 5 to 9,with the feature, that the
      or all weights are divided and connected by a pertruding joining part through the guiding track in the
      disc shaped carrier.
15         11. Conversion unit according to one of conclusions 5 to 9,with the feature, that
      two disc shaped carriers with spacing are placed parallel to each other and share one or more weights
      which are installed in the spacing between, and the or all weights show a pertruding joining part on
20      both sides of the disc shaped carriers.
         12. Conversion unit according to one of the previous conclusions,with the feature,
25      that the guiding means consist of at least one parallel to its rotational plane covering ring placed next to
      the carrier, along which the or all weights are movable.
         13. Conversion unit according to conclusion 12,with the feature, that the guiding
30      means encompass two on both sides of the carrier placed rings.
         14. Conversion unit according to conclusion 12 or 13,with the feature, that the or
      any ring runs in an eccentrically horizontal direction with regards to the rotational axle of the carrier.
NerzhDishual
Nolite mittere margaritas ante porcos.
AquariuZ
(cont)
                  (13)
         15. Conversion unit according to one of conclusions 12 to14,with the feature, that
5      the or any ring shows a mainly vertically aligned oval shape.
         16. Conversion unit according to one of the previous conclusions,featured by the
      installation of secundary housing materials around the circumference of the carrier.
10         17. Conversion unit according to conclusion 16,with the feature, that the secundary
      housing materials contain a number of spacers which run from the carrier towards the guiding materials
      and are housed by a ring which is placed around the guiding materials.
15         18. Conversion unit according to one of the previous conclusions,with the feature,
      that at least the carrier and/or the guiding materials are contructed out of glass.
END OF TEXT
